DETAILS OF YOUR VAN? off Ford ETIS - ask here!!
Re: DETAILS OF YOUR VAN? off Ford ETIS - ask here!!
Postby Rosso » Sun Apr 08, 2018 4:04 pm
Can you check SA11FFW please? Can’t get full spec via iPhone!
Cheers
Rosso
Postby paulwps » Sun Apr 08, 2018 6:26 pm
Hi , can anyone tell me how many splines on my gearbox please,
I am having problems getting a re-conditioned one
It says on the label. 3C1R 7002 EB
And are there any other compatible boxes
The vin is WF0AXXTTFA5D34639. X1
I think i have found one but they're asking for the variant ?
Reg ,NA06SYE
Thanks in advance
Paul
paulwps
Postby ned » Sun Apr 08, 2018 7:22 pm
Rosso wrote:Can you check SA11FFW please? Can’t get full spec via iPhone!
Cheers
Outstanding Field Service Actions
2C489 - TRANSIT - REAR BRAKE PIPE TO AXLE SECURING BOLT
Transit 2006-2014, 2.4L Duratorq (85kW/115PS), Frozen White
VIN Number: WF0XXXTTFXBL40810
Registration Number: SA11FFW
First Registration Date: 31.05.2011
Registration Country: GB
Type Approval Number (TAN): E1*2007/46*0248 / E1*2007/46*0264
Primary Features
Build Date: 18.05.2011
Vehicle Line: Transit 2006-2014
Cab Style: Regular Cargo Van
Series: 350M Series
Engine: 2.4L Duratorq (85kW/115PS)
Transmission: 6 Speed Manual Transmission-MT82
Drive: RHD RWD
Axle Ratio: 3.73
Emission: Stage IV Emissions
Air Conditioning:
Territory: (+)"GB"
Paint: Frozen White
Interior Colour: Lichen
Interior Fabric: Tomy (G-C)
Minor Features
With Medium Roof
Less Roof Line Conversion
With Rear Mudflaps
Less Front Susp'n Skid Plates
Less Interior Pack
Less Front Mudflaps
Wide Door Width
High Door Height
With Kerbside Side Load Doors
Less Diesel Particulate Filter
Less Brake System-Regenerative
With Full Partition - Steel
With 180° Cargo Door Check Arms
With Unrestricted Side Load Dr Opng
Less Folding Step - Side Door Load
Less Rear Door Catch
Less Liftgate
Less Second Unit Body
Less Mesh Headboard 2nd Unit
Less Tailboard Support Straps
Less Auxiliary I/P Console
With Standard GVM Rating
Otosan (Turkey) Plant Build
Less Special Equipment Package
Less Marketing Flex Prep Pack
Less Sales Badge
Less SVO Application/Label
Less Trim Pack
Less Special Value Packages
Less Power Equipment Group
Marketing Level 3
Less Visibility Package
Less Dress Up RSO
Less Utility Package
Less Certification Label
Less Fire Extinguisher Fixings
With Tool Kit
Less Tyre Repair Service Kit
With Power Front Windows
With All Light Tinted Glass
Less Front Side Door Security Glass
Less 2nd Row RH Side Window
Less 2nd Row LH Side Window
Less 3rd Row RH Side Window
Less 3rd Row LH Side Window
With Rear Blanking Panel
Less Rear Side/Back Security Glass
Less Heated Windscreen
Less Heated Rear Window
Less Overhead Console
With Header Mounted Package Tray
Less Rear Compartment Trim Panel
Less Inter Cladding Surfaces
Less Front Floor Mats
Flr Cvr-Rubber Ins-Extended
With Bright Air Vent Knob
With Partial Headlining - Moulded
With Door Map Pocket
Less Interior Grab Handle Side Door
Less Front Roof Grab Handle
Less A Pillar Assist Handle
Less 'B' Pillar Assist Handle
With Load Space Tie Down Loop
Less Load Floor Covering
Less Load Area Protection Kit
Less Cargo Stowage Rack/Rail
Less Load Compartment Tie Down
Drivers Door Trim - Level 2
Passenger Door Trim - Level 1
Less Running Boards
Less Roof Rack
Less Rear Window Protector
Less Rear Step
Less Rear View Mirror
Large Head/Short Arm Mirror
Manual Dual Mirror-Manual Fold Back
Less Seat Construction
Less Rear Underseat Stowage Bin
With Drivers Seat Fixed Armrest
Less Passenger Seat Armrests
Less Rear Seat Recliner
Less Passenger Seat Valance
Less Seat/Airbag Pack
Less 6th Row Seating
Less Temp Control Driver Seat
Less Temp Control Passengers Seat
Less 2nd Row Rear Seat
Less 3rd Row Rear Seat
Less 4th Row Rear Seat
Less Fifth Row Seating
Less Rear Seats Fixings
Less 2nd Row Reversed Triple Seat
With Driver 6 Way Mnl.Seat Adjuster
Less Adjustable Passenger Seat
Less Removable 2nd Row Seat
Less Rear Seat Armrest Packs
Less Rear Seat Packs
Less Trailer Towing Attachments
Less Trailer Coupling
Less Front Towing Hook
Rear Axle Alternative A
Less Fleet Key
With Door Auto Relocking - Enabled
Less Configurable Unlocking
With Door Dead Locks
With Power Lock Group
Two Step Door Unlock System
Less Side/Rr Door Security Lockset
With Door Entry Remote Control Unit
Less Rear Window Wiper/Washer
Less Rain Sensor - Front W/Wiper
Less Sun Roof
Less Rear Sunroof
Less Rear Bumper Under Run
Less Bumper Underrun - Front
Less Rear Seat Belts
With Driver Air Bag
Less Passenger Air Bag
Tyre Carrier Drop-Dr Open
Less Side Underrun Rails
Less Float Mounting
With Steel Spare Wheel
With Silver Wheel Finish
With Spare Tyre Security Package
With Single Rear Wheels
5.5 X 16" Steel Wheel
215/75R 16C BSW Tyres
Non Locking Lug Nuts
Diesel Fuel Cooler
Less Engine RPM Control
Cold Start Up To -20%c
Standard Electric Starter Motor
Dual Mass Flywheel
With Standard Attitude/Ride Height
With Standard Duty Front Suspension
Front Axle Rating-Normal
With Front Stabilizer Bar
With Standard Duty Rr Leaf Springs
Less Rear Auxiliary Springs
With Standard Rear Suspension
Less Rear Stabilizer Bar
With Down Turned Exhaust Exit
With Tunnel Mounted Parking Brake
Power 4-Wheel Disc Vacuum Boost
4 Wheel Anti-Lock Braking System
Electronic Stability Brk Ctrl (ESP)
Less Transfer Case
Less Skid Plates
With Sngle.L/B Dvr/Dual L/B Pass.St
Less Rear Seat Climate Control
Less Heater
With 80 Litre Fuel Tank
Less Fuel Water Separator
With Diesel Fuel Capability
With Power Steering(Variable Ratio)
Basic Type Steering Wheel
Less Auxiliary Heater
Less Heater/Air Con Prep Pack
Less Auxiliary Hot Water Heater
Less Rear Compartment Heating
With MPH/KMH Speedometer
Less Tripminder Assy
With Tachometer
Less Navigation Disk
Less Navigation Data
Less Seat Belt Warning Light
Less Reverse Proximity Sensor
Less Anti-Theft Alarm
Less Engine Immobiliser
Extra Heavy Duty Battery
Less Deep-Discharge Batteries
Standard Duty Alternator
Less Radio Pre-Equipment Pack
Less Bluetooth
Roof Mounted Radio Antenna
ICE-Low Level CD + AM/FM Radio
Ice Feature Pack 5
Less Telephone
Less Telephone Preparation Pack
Less Microphone
Less Voice Activated Modules
With Column Stalk Radio Controls
Electrical Outlet
Less Smokers Package
Less Power Point Plug - Rear
Less Camera
Less Optional Equipment Pack
Less Wheel Pack
Less Aero Pack
Less Daytime Running Lamps
Less Roof Marker/Clearance Light
Less Footwell Lights
Less Interior Courtesy Lamp
Less Load Compartment Lamp
Less Side Marker Lamps
With High Mounted Stop Lamp
Less Roof Mounted Turn Signals
Less Rear Marker Lamps
With Front Headlamp Levelling
Less Headlamp Control
Less Instrument Panel Dimmer Switch
Less Wiring Harness
Less Roof Flasher Wiring
Less Auxiliary Fuse Panel
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Postby ned » Sun Apr 08, 2018 7:26 pm
paulwps wrote:Hi , can anyone tell me how many splines on my gearbox please,
Reg ,NA06SYE
Thanks in advance
Paul
Transit 2000-2006, 2.0L Duratorq TDCI (125PS), Diamond White 73
VIN Number: WF0AXXTTFA5D34639
Registration Number: NA06SYE
First Registration Date: 09.05.2006
Primary Features
Build Date: 14.11.2005
Vehicle Line: Transit 2000-2006
Cab Style: Single Cab (2 Door)
Series: 350E Series
Engine: 2.0L Duratorq TDCI (125PS)
Transmission: 5-Speed Manual Transaxle - VXT75
Drive: RHD FWD
Axle Ratio: 4.54
Emission: Light Duty Truck Stage III
Territory: (+)"GB"
Paint: Diamond White 73
Interior Colour: Dark Graphite
Interior Fabric: Stylize (-G-C)
Minor Features
With Low Roof
Marketing Level 3
Less Header Mounted Package Tray
With Roof Height Feature Pack 3
With Front Roof Grab Handle
Large Head/Long Arm Mirror
Passenger Lrg Head/Long Arm Mirror
Fleet Key
With Driver Air Bag
Any Brand Tyre Vendor
With Brake Only Traction Control
With Manual Clutch
With Recirculating Heater
With Radio Pre-Equipment Pack 1
4000 Series
Your best making g a new post in the mk6/7 section with your question about the gearbox, you'll get the answers you need there. N
ned
Postby Rosso » Sun Apr 08, 2018 7:43 pm
Thanks Ned :D
Rosso
Postby tpmp » Mon Apr 09, 2018 5:53 pm
I'm not in the UK so I will go straight to the vin and skip the regs numbers and hope for the best
WF0LXXGBFL1E30447
And
WF0LXXTTFL5U48010
tpmp
Postby ned » Mon Apr 09, 2018 8:09 pm
tpmp wrote:I'm not in the UK so I will go straight to the vin and skip the regs numbers and hope for the best
WF0LXXGBFL1E30447
And
WF0LXXTTFL5U48010
Bit cheeky wanting 2 done :wink: :lol: :lol:
Transit 2000-2006, Duratorq DI 2.4 (90PS)
VIN Number: WF0LXXGBFL1E30447
Registration Number: 02D5362
Registration Country: IE
Primary Features
Build Date: 18.12.2001
Series: 330L Series
Engine: Duratorq DI 2.4 (90PS)
Transmission: 5-Speed Manual Transmission - MT75
Drive: RHD RWD
Axle Ratio: 4.63
Territory: (+)"IRL"
Interior Fabric: Stylize (-I-C)
No minor details available for this Belgium built van.
Transit 2000-2006, Duratorq DI 2.4 (90PS), Diamond White 73
VIN Number: WF0LXXTTFL5U48010
Registration Number: 05D59798
Primary Features
Build Date: 26.02.2005
Series: 1.7-350L Series
Drive: RHD RWD
Axle Ratio: 5.13
Territory: (+)"IRL"
Minor Features
With High Roof
LH Sliding Side Cargo Door - High
With Hinged Rear Loading Doors
Marketing Level 3
With Complete Rear Hardboard Trim
With Cargo Stowage Rail (Mid)
With Rear Step - Centre
Drivers Short Arm Power Mirrors
Passenger Short Arm Power Mirror
With Grey Plastic Rear Bumper
With Driver Air Bag
With Improved Attitude/Ride Height
With Manual Clutch
With KMH Speedometer
6000CD RDS EON
With Load Compartment Lamp
Less High Mounted Stop Lamp
ned
Postby paulwps » Tue Apr 10, 2018 4:06 pm
Thank you ned, you're a hero. :)
paulwps
Postby tpmp » Tue Apr 10, 2018 6:54 pm
WF0LXXGBFL1E30447
And
WF0LXXTTFL5U48010
Primary Features
Series: 330L Series
Drive: RHD RWD
Axle Ratio: 4.63
Territory: (+)"IRL"
Primary Features
Drive: RHD RWD
Axle Ratio: 5.13
Territory: (+)"IRL"
Minor Features
With High Roof
Marketing Level 3
With Driver Air Bag
With Manual Clutch
6000CD RDS EON
Thanks very much. first one is project van second one is donor van. Few interesting things. No paint colour for first, different diff ratios.
tpmp
Postby ned » Tue Apr 10, 2018 7:03 pm
I didn't even notice no colour for the first, what colour is it and we can probably tell you the colour (name/code) I bet the first has less rust then the second. N
ned
Postby tpmp » Tue Apr 10, 2018 7:08 pm
It's a lovely purple (inside and out)
The first one (02) has almost no rust the second one (05) has more rust than steel :lol:
tpmp
Postby ned » Tue Apr 10, 2018 7:39 pm
Purple? Not pepper red, yes the 02 van is a Belgium built van which seem to be very well protected against rust :P my 03 is a Belgium build and has very little rust (nothing a good day wouldn't fix) :D N
ned
Postby tpmp » Tue Apr 10, 2018 8:07 pm
Not pepper red, definitely purple. I think it's an ex United drug van. Think barney the dinosaur :lol: but it's definitely factory painted inside and out
I was about to ask why you thought it had little rust :P
tpmp
Postby ned » Tue Apr 10, 2018 8:14 pm
Ah sounds like a custom colour hence why its not stated on etis, bit like post office red or omega blue :wink: N
ned
Postby Olliec » Tue Apr 17, 2018 8:14 am
Hi. Could you give me the details for YG13 EZM please.
Olliec
cron
