tpmp wrote:I will try again
WF0EXXTTFE4C51371
stary231231 wrote:thank you. nad is some detailed about weight?
ned wrote:tpmp wrote:I will try again
WF0EXXTTFE4C51371
Transit 2000-2006, Duratorq DI 2.4 (90PS), Diamond White 73
VIN Number: WF0EXXTTFE4C51371
Registration Number: NM04EHP
First Registration Date: 20.07.2004
Registration Country: GB
Primary Features
Build Date: 16.05.2004
Vehicle Line: Transit 2000-2006
Cab Style: Bus (M2)
Series: 1.7-350L Series
Engine: Duratorq DI 2.4 (90PS)
Transmission: 5-Speed Manual Transmission - MT75
Drive: RHD RWD
Axle Ratio: 5.13
Emission: Light Duty Truck Stage III
Territory: (+)"GB"
Paint: Diamond White 73
Interior Colour: Dark Graphite
Interior Fabric: Stylize (-G-C)
Minor Features
With Medium Roof
LH Sliding Side Cargo Door - High
With Hinged Rear Loading Doors
With 180° Cargo Door Check Arms
Otosan (Turkey) Plant Build
Less SVO Application/Label
Marketing Level 3
With Power Front Windows
With RH 2nd Row Sliding Window
With LH 2nd Row Sliding Window
With RH 3rd Row Flip Open Window
With LH 3rd Row Flip Open Window
With Fixed Rear Window
With Heated Rear Window
Less Header Mounted Package Tray
With Complete Rear PVC Trim Board
With Rubber Floor Covering
With Full Headlining - Moulded
With Roof Height Feature Pack 7
With Sunvisor Mirror - Passenger
With Door Map Pocket
With Front Roof Grab Handle
With A Pillar Assist Handle
With B Pillar Assist Handle
Drivers Door Trim - Level 2
Passenger Door Trim - Level 1
With Rear Step - Centre
Drivers Short Arm Power Mirrors
Passenger Short Arm Power Mirror
With Drivers Seat Fixed Armrest
Less Passenger Seat Armrests
Less Passenger Seat Valance
Less Temp Control Driver Seat
Less Temp Control Passengers Seat
With Driver 6 Way Mnl.Seat Adjuster
Less Adjustable Passenger Seat
Less Trailer Towing Attachments
With Central Locking System
With Door Entry Remote Control Unit
With Dual Rear Window Wiper/Washer
With Grey Plastic Rear Bumper
With Driver Air Bag
With Passenger Air Bag
With Adjustable 'D' Ring Pass Seat
With Spare Tyre Security Package
215/75R 16C BSW Tyres
Any Brand Tyre Vendor
Less Engine RPM Control
Cold Start Up To -20%c
4 Wheel Anti-Lock Braking System
With Sngle.L/B Dvr/Dual L/B Pass.St
With Manual Clutch
With Recirculating Heater
With MPH/KMH Speedometer
Heavy Duty Alternator
With Radio Pre-Equipment Pack 2
4000 Series
With Interior Courtesy Lamp
With High Mounted Stop Lamp
With Front Headlamp Levelling
loot wrote:I'd go off the vin plate.
It's interesting that it is different on the Irish plates I would expect it to be the same or not found.
Was it only registered on the Irish plates?
Just curious.
tpmp wrote:I'm going to be cheeky again and look for an Irish regarding to be done. Stumbled across this one packed up today due to rust
04LS3606
Just curious.
simon01775 wrote:Hello
I am just replacing my mk6 lpg with a mk7 T280 GLX. Can any one tell me what ETIS says about my new van? GV08VCD. Thanks in advance for any replies.
Simon
maco wrote:Hi not sure what info you need but having a few concerns with my van, thinking it could be a ringer!
NL60FGV is the Reg, thanks
trans-it-mad wrote:hey there, can you please tell me the detail of my van, I have some mystery in my v5 to sort out.
WF0LXXGBFL2R80143
Ta!
Users browsing this forum: Burf86, Google Adsense [Bot]
