Mk7 EGR valve - Disconnect?
Postby pusd » Mon Jan 05, 2009 12:23 am
Hi, is it possible to disconnect the EGR valve to prevent it's operation?
If so are there any benefits or side effects and how is this best achieved without activating the engine management light?
Reason I ask is that I have had good results from disconnecting their operation in older (mechanical pump) diesels and have heard of quite a few EGR failures causing running problems.
Cheers all, Phil
pusd
Re: Mk7 EGR valve - Disconnect?
Postby ake » Mon Jan 05, 2009 9:22 am
If you unplug it it brings on the management light
Postby pusd » Mon Jan 05, 2009 10:40 am
Is there any other ways, like, making a plate to block the passage between the exhaust & inlet tract?
This would leave the egr fully working but still block the flow of gasses???
Anyone done this?
Cheers, Phil
pusd
Postby Mike » Mon Jan 05, 2009 11:20 am
It's been suggested that you could take out the middle gear to stop it moving the valve.
Mike
Wind up merchant!
Postby Hydraulic Bloke » Mon Jan 05, 2009 11:36 am
Back in the early days we used to just put a ball bearing in the pipe entrance
You can go as fast as you want on a push bike
Hydraulic Bloke
Postby Mike » Mon Jan 05, 2009 12:01 pm
Hydraulic Bloke wrote:Back in the early days we used to just put a ball bearing in the pipe entrance
I think that throws up a fault on the MK7.
Mike
Wind up merchant!
Postby Frag » Mon Jan 05, 2009 2:12 pm
Mk7`s are electric not vacuum so that`s not "applicable".
Frag
Ford Technician
Postby pusd » Mon Jan 05, 2009 3:15 pm
So, has anyone had a go at disconnecting the EGR - by removal of the middle gear (sounds interesting) or any other means (except pulling the multiplug & putting on the E/M light).
Don't want to start fiddling with too complex stuff only to find that she runs like a dog or still ends up putting the engine management light on!
In the good old days of diesels I used to simply put a 1" long piece of nail into the vacuum pipe....
Cheers all
Phil
pusd
Postby gpz900r » Mon Jan 05, 2009 4:39 pm
hi my mechanic who works at ford blanked it off with some sort of washer no probs whats so ever done at lest 8000 miles so far since its been done i beleive it just recycles unburnt gases someone will put me right if this isnt the case.
gpz900r
Postby coconut » Mon Jan 05, 2009 8:30 pm
gpz900r wrote:hi my mechanic who works at ford blanked it off with some sort of washer no probs whats so ever done at lest 8000 miles so far since its been done i beleive it just recycles unburnt gases someone will put me right if this isnt the case.
Is yours a mk7 :?:
If so, any chance of speaking to him and finding out how he done it :D
I miss my 'courtesy van'............140 Glx..now a Jumbo :(
coconut
Ford Technician
Postby Victer van man » Mon Jan 05, 2009 10:27 pm
Tried blanking mine off with a plate where pipe fits on the back of EGR..... no joy..... drilled a small hole in it
still no joy, both ways threw MIL light on.
At the moment EGR is knackered so running with a blanking plate with MIL light on cos it won't pull
me granny off her p@@s pot with out it.
Apparently there is a completely new revised EGR been released with seperate electrics,
which according to a reliable mechanic at my local stealers is the problem, something to do with the
heat from the EGR.
He's ordered one for me just waiting delivery, will keep you posted when it comes
[b]Jumbo driver's go the distance[/b
Victer van man
Postby pikeybob » Mon Jan 05, 2009 10:45 pm
How much is an EGR valve if i had to buy 1? Mines still on its original with only occasional rough idle (normally only when very cold out) Or should i get it sorted under warranty b4 it knacks? vans done 19k and just over 2 years old.
The only mk7 still with ORIGINAL egr valve!!!!!!
pikeybob
Postby Victer van man » Mon Jan 05, 2009 11:13 pm
pikeybob wrote:How much is an EGR valve if i had to buy 1? Mines still on its original with only occasional rough idle (normally only when very cold out) Or should i get it sorted under warranty b4 it knacks? vans done 19k and just over 2 years old.
If its only done that get it sorted on warranty. Mines done 144,000 so had to buy mine. This is the 2nd one I've
bought, but 2 previously fitted on warranty £97+ VAT trade
Victer van man
Postby pikeybob » Mon Jan 05, 2009 11:38 pm
Ok thanks victer van man i have to get on to Lincoln Ford, perhaps they will fix my knackered keyfob this time a well :evil: They only sorted one as the other worked at the time, even though they said it would pack up :( anything 2 save a few quid. Oops now im waffaling sorry :oops:
pikeybob
Postby ake » Tue Jan 06, 2009 7:31 pm
pikeybob wrote:Ok thanks victer van man i have to get on to Lincoln Ford, perhaps they will fix my knackered keyfob this time a well :evil: They only sorted one as the other worked at the time, even though they said it would pack up :( anything 2 save a few quid. Oops now im waffaling sorry :oops:
When my van was new it got 3 keyfobs in as many months, The current one has lasted 18 months tho :)
