Mk7 EGR valve - Disconnect?
Re: Mk7 EGR valve - Disconnect?
Postby pusd » Thu Mar 19, 2009 10:24 pm
pikeybob wrote:If it was the injectors surley it would have been like it from new :? Does running the van with the eml showing have an adverse effect on the engine itself
Dunno, but mine runs fine with it showing!!!
Although I'm unsure as to whether it is safe to run with the EGR multiplug disconnected for a prolonged period of time.
Phil
pusd
Postby pikeybob » Thu Mar 19, 2009 10:28 pm
Ur EGR fubar as well Phil :?:
The only mk7 still with ORIGINAL egr valve!!!!!!
pikeybob
Postby winterheating » Thu Mar 19, 2009 10:39 pm
pikeybob wrote:U mean this git :?:
do these egrs have a motor on them then :?:
winterheating
Postby pikeybob » Thu Mar 19, 2009 10:45 pm
Not a clue Coconut knows what hes on about with these buggers :wink:
pikeybob
Postby winterheating » Thu Mar 19, 2009 10:48 pm
looks like with them wires a motor and position sensor, :?:
winterheating
Postby pikeybob » Thu Mar 19, 2009 10:58 pm
Cant blank it off unlike the mk6. Mk7 to clever 4 its own good, it knows when things r disconnected doors not shut, cant even fool it by locking the door catch with the door open so the interior light goes off, then pressing lock on the keyfob, it still blasts the horn n cycles the locks. How the hell does it know :?: Seen the film Terminator :?: Its coming true i tell thee :wink: :lol:
pikeybob
Postby pusd » Thu Mar 19, 2009 11:19 pm
pikeybob wrote:Ur EGR fubar as well Phil :?:
Not that I know of!!!
Just been playing about to see if it can be 'deactivated' without putting up a dash light!
...which it can't :oops:
Phil
pusd
Postby Victer van man » Thu Mar 19, 2009 11:37 pm
ake wrote:
pikeybob wrote:Think its going ake even the missus has commented on the crazy idling :(
Thats exactly what mine is doin AGAIN :(
Mine too!!!!!!!! only done 6k since I fitted the last one
[b]Jumbo driver's go the distance[/b
Victer van man
Postby coconut » Fri Mar 20, 2009 12:40 am
Yep, the bigger round bit is the motor which turns 3 gears which opens and closes the valve, or in theory thats what happens :P
Lumpy idles seems to be a number of things at the minute, different vans have different fixes, some have egr's, some pcm calibration, some imv, some pressure relief valve, some map sensor etc etc, one of those things you dont know until its plugged in :(
I miss my 'courtesy van'............140 Glx..now a Jumbo :(
coconut
Ford Technician
Postby ake » Fri Mar 20, 2009 7:29 am
pikeybob wrote:You had urs done once already Ake :?:
Yes mine got one at 24k and its now at 46k and its at it again, but reading coconuts last post maybe its somethin else :?: I'll have to get it in :(
Postby jacko1611 » Fri Mar 20, 2009 8:52 pm
coconut wrote: Lumpy idles seems to be a number of things at the minute, different vans have different fixes, some have egr's, some pcm calibration, some imv, some pressure relief valve, some map sensor etc etc, one of those things you dont know until its plugged in :(
or one after the other until ids brings up the diagnostic that u want to do!
not another E G F*****G R!
jacko1611
Ford Technician
