Can i lock my van from outside and leave it running
Postby The Lone Wolf » Tue Jan 13, 2009 8:49 pm
Can i start my van.
Get out of it and leave it running.
Lock it with the remote keyfob.
Come back to it and open again with remote fob.
I like to start up and demist the screen / warm the cab before taking off.
But would rather be in the house making me sarnies while its demisting / warming.
The Lone Wolf
Re: Can i lock my van from outside and leave it running
Postby Frag » Tue Jan 13, 2009 9:05 pm
No,not with fob it doesn`t work while ignition is on i`m sure.
You could with key......
Bearing in mind someone can pot the window & steal keys or whole van.....
S`pose it depends where you live but someone also said years ago it`s illegal to leave a vehicle running like that,don`t know how true it is.
Some jobsworth told me while i left car running at minibank,8 feet away & with our gert sat in car :roll:
Frag
Ford Technician
Postby ake » Tue Jan 13, 2009 10:04 pm
I start mine with one key and lock it with another but i know insurance won't pay out if someone does smash window and nick it
Postby Daveyboy » Wed Jan 14, 2009 6:17 pm
Reminds me of a mate of mine, he's in his 40's and still lives at home with his mother, she's in her 70's still does all his washing/cooking and when cold weather/frosts forecast she gets up especially early to start his car up and make sure its defrosted and nice and warm for him. :lol:
Daveyboy
Postby WINDSCREENGUY » Wed Jan 14, 2009 7:20 pm
i do have a way of leaving your van running but with no key in the ignition but you won be able to lock the van.
which dosent matter as your steering lock will be on and as soon as someone releases the hand brake the van cuts out and cannot be restarted without the key.
i have done this to my van as i leave it running whilst im using the hoover powered by my invertor.
its very easy to do you just need a reley ,hefty switch, in line fuses, some cable and a switch on the hand brake.
formally grey van man.
2010 115 semi high mwb . Fully loaded.
WINDSCREENGUY
previously grey van man
Postby Frag » Wed Jan 14, 2009 9:47 pm
You can buy a kit that does just that,emergency services use them & i`ve fitted about 30 to council vehicles with taillifts.
Does same as you say,fire it up press a button then remove keys.
Has h/brake wire,i use the mondeo h/brake switch.If van has tipper with box near radio (VFS body) there is already a h/brake switch fitted :D
Frag
Ford Technician
Postby Daveyboy » Wed Jan 14, 2009 10:05 pm
Frag wrote:You can buy a kit that does just that,emergency services use them & i`ve fitted about 30 to council vehicles with taillifts.
I guess this kit is fitted to cherry pickers too, my next door neighbour works for the council street lighting dept, and in the cold weather he starts up his Merc Vario, (great fun at 6.00 am at the weekend) and leaves it to warm up. :evil:
Daveyboy
Postby Frag » Wed Jan 14, 2009 10:07 pm
Nah,he probably just leaves keys in :lol: :lol:
Go & have a look,then move it a couple of streets away :P
Frag
Ford Technician
Postby Daveyboy » Wed Jan 14, 2009 10:33 pm
Frag wrote:Nah,he probably just leaves keys in :lol: :lol:
Yeah I,m tempted, thought mk5's were noisy!!!
Daveyboy
Postby The Lone Wolf » Mon Jan 19, 2009 10:50 pm
Sounds like a NO then.
What i will do is.
Start it.
Open drivers window.
Get out.
Lock it with remote fob.
Leave it running for about 15 mins (about same time it should normally take to warm cab)
Try to open it again with fob.
If it don't work,
i'll be able to get in through window !
Will let you know how i get on
The Lone Wolf
Postby Hilborns Motorsport » Mon Jan 19, 2009 10:55 pm
or buy a clifford alam with in car telestart push a button from in ya house and it will start but all be aremd up still untill unlocked with keyfob
Hilborns Motorsport
Sportvan Owner!
Sportvan Owner!
Postby sootymax » Mon Jan 19, 2009 11:07 pm
i had a aftermarket remote start on one of my audis it was great started up when it got below a temp i put in or even a time i wanted like a alarm clock great one to show the lads pressed a button and it fired up loved it but sold the car
2yrs down the line m8 rang me up it went up in flames the ecu for the remote start was the cause of it doh :roll:
sootymax
Postby The Lone Wolf » Wed Jan 21, 2009 5:33 pm
The Lone Wolf wrote:Sounds like a NO then.
What i will do is.
Start it.
Get out.
If it don't work,
Tried it.
No. It will not work.
Thanks for replies people !
The Lone Wolf
Postby sc_BK » Wed Jan 21, 2009 6:40 pm
The kit Frag is talking about is called runlock (or simmillar), about £50-£100
sc_BK
Postby gpz900r » Mon Jan 26, 2009 5:05 pm
i found away i wasnt looking for one thou 2.4duratorq 55 reg rwd jumbo delivering in leicester one night 2.00am done drop off got out van with engine running shut door went to lock gates went to get in van doors are all locked engine running now im b*ll*cks engine running doors locked keys inside phone inside no local phone thounsands of pounds of stock on board no one about due time of day. never a plod about when you could do with one, only one thing to do find find metal thingy smash window which i did (quarterlight) what caused this problem. over a period of time the wiring on the back doors had sometimes became trapped and had kinked causing the central locking to operate so now i make sure when i close the doors i feed the wire in to the proper place (bad design) also the wind catches the doors causing same problems (trapped wire) no magnets to keep doors open (another bad design). while im at it the times when loading the van i have nearly caught some part of my head on the things(dont no what you call them) that stick out door guides? another bad design
ps if you ever have to smash a window for what ever reason assuming its your own van dont go for the quarter light its more expensive than the side window the only thing is the shattered glass clean up after getting glass out of window runners, winders , etc.
gpz900r
