Changing Headlight Bulbs on mk6
Postby Scotty86 » Fri Feb 06, 2009 4:29 pm
How do you change the headlight bulbs on the mk6?
2017 Transit Custom SWB RSV
Scotty86
GLX Posse
Re: Changing Headlight Bulbs on mk6
Postby sc_BK » Fri Feb 06, 2009 4:47 pm
With great difficulty :wink: :lol:
Easiest way is prolly to take out the headlight, less risk of fingers on bulbs
sc_BK
Postby Scotty86 » Fri Feb 06, 2009 5:07 pm
Oh well, something else to try and do when I have some freetime, got to change old bulbs and sidelights to my new ones.
Scotty86
GLX Posse
Postby Guy88 » Fri Feb 06, 2009 7:13 pm
undo the bolts holding the fuse box in and lift it up a bit :wink:
2005 Ford F250 Super Duty
1992 MK3 ambulance
1980 A Series crew cab
1984 A series RB44
LIVIN' LOUD
Guy88
Postby Scotty86 » Fri Feb 06, 2009 7:49 pm
Where's the fuse box?
Scotty86
GLX Posse
Postby jacko1611 » Fri Feb 06, 2009 8:50 pm
there not that hard. o/s/f is hard if it has a/c
not another E G F*****G R!
jacko1611
Ford Technician
Postby Guy88 » Fri Feb 06, 2009 10:39 pm
Scotty86 wrote:Where's the fuse box?
above n/s headlight
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Postby ake » Sat Feb 07, 2009 10:10 pm
Scotty86 wrote:How do you change the headlight bulbs on the mk6?
I've just realised that after owning a MK6 in the past and having driven dozens of them, I have never had to change a headlight bulb in a MK6, unlike my MK7 which gets at least one every 3 months :lol:
2 x 67 Custom 270 Trend
3 x 66 Custom 270 Trend
1 x 65 Custom 290 Limited
7 x 12 Transit 260 Trend
1 x 60 Transit 350
Or is it something worse?
Postby alzee20 » Sun Feb 08, 2009 1:21 am
well easy man just get yer hand in there!
mk7 280 115ps swb fwb lr - 20000 miles so far..!
mk6 280 75ps swb fwd lr - Dead but took a sprinter with her! :)
mk6 280 75ps swb fwd lr - Vantunered!
alzee20
Postby Scotty86 » Sun Feb 08, 2009 4:37 pm
Was pretty easy actually just changed headlights and sidelights now. Before I changed them all, both sidelights were not working, changed both of them now and driver side is still not working, thought it may have been bulb so changed it to another one and its still not working. Could it be a fuse or dodgy wire? What's a good way to check?
Scotty86
GLX Posse
Postby sc_BK » Sun Feb 08, 2009 4:53 pm
Sometimes the bulb holders for the wedge type bulbs can be a bit intermitant, if the bulb isn't properly lined up the connections aren't made
You can see if power is getting through to the holder using a multimeter
sc_BK
Postby coconut » Sun Feb 08, 2009 5:24 pm
Is the OSR side light working :?:
I miss my 'courtesy van'............140 Glx..now a Jumbo :(
coconut
Ford Technician
Postby Scotty86 » Sun Feb 08, 2009 5:48 pm
coconut wrote:Is the OSR side light working :?:
Passenger side? Yes it is, just drivers side not working
Scotty86
GLX Posse
Postby coconut » Sun Feb 08, 2009 5:54 pm
No, I mean is the drivers side rear side light working cus if its not then its most likely to be a fuse :)
coconut
Ford Technician
Postby Scotty86 » Sun Feb 08, 2009 5:56 pm
Its working fine :)
Scotty86
GLX Posse
Users browsing this forum: Bing [Bot], martin1vol
