winterheating wrote:syGuy88 wrote:can you not take the motor out and operate it all by hand and remove the deadlockpaul0li wrote:I'd like to try that, but I cant get at it from the inside with the door locked.. Unless you know how
the motor part is the bottom of the lock where the 3 wires go to, can remove that from inside.
ive got one laid about somewhere i'll have a look see how easy it comes off.
winterheating wrote:have you checked theres a voltage getting to the wires, when pressing fob just before you start dismantling a a good lock?
the wires come down that pillar, is there anything screwed in the back that may hgave damaged the loom
winterheating wrote:looks like you'll need a new lock/motor then
thunderider wrote:tried putting the key in the drivers door turn it rightt twicce,or left twice as tis also activates the double locking
Users browsing this forum: Askeladd, Crispin007
