Rear door lock
Rear door lock
Postby owen » Wed Jul 22, 2009 4:48 pm
I am having a problem with my rear door lock, in that i am completely unable to lock it! (van is x reg 330mwb)
My local mechanic reckons it is the rear door lock. Got a price from ford, £185 :shock: :shock: :shock:
I managed to find one in a scrapyard today, but it is slightly different from mine, and doesn't fit. I can't find anything else locally, and there's nothing on ebay. Also, there's no part number to definitely identify it, so i am reluctant to buy 2nd hand parts over the internet/mail order as there's a good chance they won't be the right ones either.
Any ideas before i go to ford and bend over?? :cry:
owen
Re: Rear door lock
Postby Frag » Wed Jul 22, 2009 6:53 pm
Wiring looms to rear door kink & wires break more often than latch failures (or would be thieves cut loom in aperture between van pillar & door),suggest you remove rear door trim panel & have a look.
Does it make any noise when locking or unlocking ?
Frag
Ford Technician
Re: Rear door lock
Postby owen » Wed Jul 22, 2009 9:20 pm
Frag wrote:Wiring looms to rear door kink & wires break more often than latch failures (or would be thieves cut loom in aperture between van pillar & door),suggest you remove rear door trim panel & have a look.
my autoelectrician has already repaired the wiring once, i don't think it is that. if you turn the key, nothing happens. i don't think the key will turn far enough to do anything, it feels like something is jammed.
owen
Re: Rear door lock
Postby GBBiker » Wed Jul 22, 2009 9:25 pm
I didn't think MK6s had key locks on rear doors :?
I've not come across any. All the MK6s I've had have only had a key lock on the driver's door, the rest are blanks.
GBBiker
Wrong Again!
Re: Rear door lock
Postby Frag » Wed Jul 22, 2009 10:27 pm
Some early ones have a lock barrel in rear doors (& passenger),ones without central locking have a barrel in every door.
How worn is your key,have you tried a spare ?
Do you have a remote fob,or does your van not have remote locking ?
Frag
Ford Technician
Re: Rear door lock
Postby owen » Mon Jul 27, 2009 6:39 pm
Frag wrote:Some early ones have a lock barrel in rear doors (& passenger),ones without central locking have a barrel in every door.
the key is quite worn, but i have just tried the spare with no success.
yes the van has remote locking.
i have just received another lock via mail order, despite the bloke assuring me that it is the right one, it isn't - i can see no way of fitting the lock barrel into it so that turning the key actually does something :?
owen
Re: Rear door lock
Postby owen » Sat Aug 29, 2009 9:05 pm
well i finally managed to modify the new one to fit, it works fine now thankfully. very frustrating not being able to get the right one though, why don't ford put a part number on it?? :?
owen
Users browsing this forum: Bing [Bot], Bsu68, Majestic-12 [Bot]
