135 timing btdc
135 timing btdc
Postby angeleye » Sun Oct 11, 2009 10:40 am
finding it difficult to get at flywheel sensor to try and get a pin in to time engine, does anyone no what the distance the piston is supposed to be from top of head i can set timing with dial test indicator, if i new setting,.....(grollie )i read your post i no you set your similar way, have not got tis disc ,is the timing 10mm btdc, and set cams, thanks
angeleye
Re: 135 timing btdc
Postby Frag » Sun Oct 11, 2009 8:35 pm
Not much help but i`m sure tdc (50 degrees before) is around 22 or 24 mm on No1 piston from block surface to piston top edge :?
Frag
Ford Technician
Re: 135 timing btdc
Postby winterheating » Mon Oct 12, 2009 2:54 am
hope this helps aswell
rotate the crankshaft until piston no1 is approximetely 10mm BTDC
zero the dial indicator gauge
mark the position on flywheel primary mass
crankshaft clockwise
rotate crankshaft until piston no1 achieves zero on the dial indicator gauge.
mark position on flywheel.
repeat to make sure mark is correct
the middle of the markings is TDC measure the distance between the 2 marks
divide the amount by 2 AND MARK position TDC on flywheel
measure the circumference of the flywheel
multiply the circumfrance by 0.1388
mark the calculated amount on flywheel by measuring from TDC anticlockwise
1 first mark
2second mark
3determind TDC
4determined 50 degrees BTDC
winterheating
Users browsing this forum: Bing [Bot], Brains_transit, Google [Bot]
