HELP!! Mk6 Fuel pump problem??? Martin or Coconut u there???
Re: HELP!! Mk6 Fuel pump problem??? Martin or Coconut u there???
Postby whogotmelighter » Fri Oct 16, 2009 9:48 pm
vitoansit wrote:Have you tried to crack open one of the injectors to see if fuel is coming out? If it is still coming out it sounds to me as if it's your fuel pmp timing. The edc can be taken off the pump and fixed had mine done 3 months ago and it's been fine since. The folk that fixed it were chipgods.com email mark@chipgods.com or phone him on 07732033551
where is this edc and what does it do ?
thanks
51 reg t350 125 lwb hi roof
whogotmelighter
Postby vitoansit » Sat Oct 17, 2009 6:30 am
thanks
It's part of the pump. Electronic Diesel Control Unit.http://www.dieselpumprepairs.com/ Watch the vid .You can take it off with the pump still in place which is what I done,I posted it away when it came back just put it back on and away it went. I wonder how many folk have had the full fuel pump replaced when they could have just had this edc fixed?
vitoansit
Postby Gurj51ngh » Sat Oct 17, 2009 9:14 am
Thanks for all your help mate. I am going to give them a call on Monday and see what they say. Hopefully we can have something sorted.
Thank you
Gurj51ngh
Forums Loudest Van!
Postby whogotmelighter » Sat Oct 17, 2009 3:03 pm
thanks
i got quoted £800.00 for one, expensive for something that i don't know is faulty, gonna get mine off and send it away. where is the fuel pump located on the rwd mk6's?
whogotmelighter
Postby Gurj51ngh » Sat Oct 17, 2009 5:10 pm
[/quote]
i got quoted £800.00 for one, expensive for something that i don't know is faulty, gonna get mine off and send it away. where is the fuel pump located on the rwd mk6's?[/quote]
X2 to all of that!
Gurj51ngh
Forums Loudest Van!
Postby winterheating » Sat Oct 17, 2009 5:13 pm
have you took rocker cover off yet to check for damage :?:
winterheating
Postby Gurj51ngh » Sat Oct 17, 2009 6:28 pm
winterheating wrote:have you took rocker cover off yet to check for damage :?:
No mate I have not doen this yet as I have been out today van hunting. But I will check tomorrow and post up. So all I need to do is take the rocker cover of and check all the bolts underneath are fully tight??
Thank you :)
Gurj51ngh
Forums Loudest Van!
Postby winterheating » Sat Oct 17, 2009 7:23 pm
yeah it wont do any harm, then if bolts are loose good chance timings jumped. :wink:
winterheating
Postby Gurj51ngh » Mon Oct 19, 2009 10:26 am
I need a good mobile mechanic around London / Essex to pop over and do a proper diagnostic check up on the van. Anyone available?? Need this doing ASAP as I am vanless.
Thank you
Gurj51ngh
Forums Loudest Van!
Postby madmark_50484 » Mon Oct 19, 2009 11:18 am
Where abouts is the van ? I'm not a mechanic but I could take a look if your local to me.
Past
MK5 98 R reg Transit 190 LWB Semi hi Top
Mk5 98 S reg Transit 190 LWB High Cube
Present
Mk5 96 N Reg Transit Luton
Forum for bus enthusiasts and preservationists
www.busesuk.co.uk
madmark_50484
Postby Gurj51ngh » Mon Oct 19, 2009 7:59 pm
The van is on the A12 Mark near MobyDick the pub near chadwell heath. Transit Geoff has hooked me up with one of his mates who will pop down tomorrow to take a look. So I will post up on progress need to get the van sorted!!
Gurj51ngh
Forums Loudest Van!
Postby madmark_50484 » Mon Oct 19, 2009 8:10 pm
Gurj51ngh wrote:The van is on the A12 Mark near MobyDick the pub near chadwell heath. Transit Geoff has hooked me up with one of his mates who will pop down tomorrow to take a look. So I will post up on progress need to get the van sorted!!
No problem hope its nothing too serious
Past
Present
www.busesuk.co.uk
madmark_50484
Postby martynx » Tue Oct 20, 2009 3:46 pm
Sorry Gurj - I had the worst flu/migraine/backache\ combo i have ever known :cry: - I didnt go near a PC till the weekend had to turn everything off for a few days.
Your problem sounds like classic pump ecu ( aka edu) failure , but of course , read & clear codes & see what returns after a regular , ( non tow ) start attempt & we will act on that :)
I have asked Guy88 about an old 90 pump he offered me some time back & that may , if its still available , make an ideal donor if your pump or just pump ECU is mash-up - you could put his ecu on without removing your whole pump maybe to save some hrs.. :idea:
If that's the route to go I'll come over & re-initialize everything to your main ECU no problem...
On an ultra low budget vibe - i know roughly how to repair the pump ecu's common problems but not done one yet so may not be best / fastest solution.. :)
Let us know what the diag man says today &
I'll let you know if guys pump is available ..
Martyn.
for egr/dpf deletes, power tuning, updates,cloning,speed limiter removal,cruise control, euro 3/4/5/6 limiters & key's !
martynx
Postby Gurj51ngh » Tue Oct 20, 2009 8:36 pm
Thanks for getting martin! Glad your all well mate we all need our remapping GURU to be well :P :lol:
Anyways the guy popped over today and the two fault codes that came up are
P1564
P1664
He said when these two faults come up together this mean the pump or in other words the EDC has had it! He tried to clear them but it would not have it!
I did speak to Guy but he has got shot of his engine with the pump :(
But I have found a firm who can repair the EDC I just need someone to pull it out for me. Apparently it can be done whilst the pump is still in place :?: :? I dont fancy doing it so need someone to pop over.
Also for anyone following this thread pup cost are
NEW from FORD £850.00 plus £200.00 labour charges from local mobile mechanic.
Recon pump from Transit parts with guarantee £600.00 labour charges same.
Second hand pump around £200.00 - £350.00 if you can find one. But only buy one from someone you know!!!
Plus you need to add another £50.00 on all the above charges to have the pump re programmed to your ECU! SO all in all very expensive sh*t!!
Best option is send you EDC of for a check up to these guys http://www.dieselpumprepairs.com/#/cont ... 4533011261
Or have a chat with Martynx (vantuner)
Gurj51ngh
Forums Loudest Van!
Postby belly » Tue Oct 20, 2009 9:30 pm
Glad your getting there Gurj :D cheers for the heads up! When I get a chance I think I will start stripping mine down! Keep the reports going though mate :D
belly
Kaiser Chief
