EastCoast-Transit wrote:HI
Is it the calipers? (or is there a caliper 'slide' that may be sticky)?
What's a 'flexi'?, could it be this? (There are about 4mm or 5mm diameter metal tubes coming out of the master cylinder, not flexible hoses?.. are there flexible hoses used further along?)
Cheers Joe
EastCoast-Transit wrote:Hi
Thanks for the replies... much appreciated.![]()
Yes, there is a flexi pipe at the wheel arch, (as you all already know).. it looks fine but I'll get it replaced.. I hope it can be purchased as a seperate part, or made up from stock tubing... the fact that the pressure is released slowly over time, that the problem is on one wheel only and that the problem is intermittent seems to indicate the flexi hose...
I'll also insist that the mechanic examines the piston slider in the caliper for signs of stickiness...
Cheers so,
Joe
Users browsing this forum: Bing [Bot], Google [Bot]
