TDCI high fuel pressure ford dont know whats wrong
Re: TDCI high fuel pressure ford dont know whats wrong
Postby lightning » Thu Feb 18, 2010 9:41 am
Any chance you could let me have the procedure for updating the PCM? I just know what will happen if I go back to the dealer without some "ammunition" !
lightning
Postby martynx » Thu Feb 18, 2010 12:45 pm
plug in dealer kit & goto module programming & the tool will tell you if theres an update available.. there's no option , or possibility to force an update or restore a previous one & no info on what any new update addresses.
Have you written to customer care ? also i would seriously consider the inconvenience of travelling to another dealer.. You clearly have a fault & should go absolutely ape at someone till its sorted ... get the next service manager to drive with you till it happens...
for egr/dpf deletes, power tuning, updates,cloning,speed limiter removal,cruise control, euro 3/4/5/6 limiters & key's !
martynx
Postby lightning » Fri Feb 19, 2010 9:24 am
Thanks for the advice. To be honest it's hard to demonstrate the faults as they are fairly minor. The dealer has had the van in and I know the engineer road tested it.
If there is not an update available for the PCM can the operator force the computer to re-install the existing software? Just on the off chance there was a fault with the previous update? If not there's no point in me going back to the dealer (I just booked it in again)
The odd thing is, I installed BLUEFIN and while it improved the performance, it made the "not smooth" part throttle acceleration much worse and I had to send it back.
lightning
Postby martynx » Fri Feb 19, 2010 12:49 pm
You cant go back on these PCM updates unfortunatley or even reinstall the newest ...
Like any generic remap a blufin could cure it or make any symptom worse so dont read anything into that..
Have you tried millers ecomax additive ( ebay £9.00 ) that may help :?:
martynx
Postby lightning » Fri Feb 19, 2010 5:51 pm
No not tried any additives, I'll give that a try. Thanks for all the advice.
lightning
Postby martynx » Fri Feb 19, 2010 7:50 pm
Find the EGR valve & disconnect it ... ?
martynx
Postby lightning » Sat Feb 20, 2010 12:48 am
I heard about disconnecting the EGR valve, various opinions on doing this. Some say there's no point and others that it's worth doing.
If it's easy to disconnect/bypass I'll give it a try.
lightning
Postby winterheating » Sat Feb 20, 2010 12:52 am
lightning wrote:I heard about disconnecting the EGR valve, various opinions on doing this. Some say there's no point and others that it's worth doing.
its worth doing especially if its not operating correcty and causing your fault
winterheating
Postby james.knoedl » Tue Feb 23, 2010 9:10 pm
Hi,
I had the same trouble with the MK6 125 TDCI and it turned out to be the Throttle Pedal box.
I took it off by the footwell and cleaned the connections and it was perfect!
It might be the same as the MK7 but who knows?
james.knoedl
Postby Surfunitone » Mon Oct 26, 2015 7:08 pm
Sorry for posting on an old thread... did you get to the bottom of this?
2.2 Duratorq-TDCi (110PS)
Surfunitone
Postby knobby1 » Mon Oct 26, 2015 8:31 pm
Surfunitone wrote:Sorry for posting on an old thread... did you get to the bottom of this?
Thread is nearly 6 years old, highly unlikely the OP is still around or active...
Postby martynx » Tue Oct 27, 2015 12:02 am
This was simply a faulty van in the wrong hands( probably!;)... ).all problems discussed are very well understood now, 5 years on..
martynx
Postby Surfunitone » Thu Oct 29, 2015 12:17 am
Yeah sorry for resurrecting the dead :)
Surfunitone
