windscreen washer fuse location
Postby jerryh » Tue Feb 16, 2010 5:59 pm
hi,
does anyone have the fuse layout for a 2005 transit, i do not have manual and nothing written on cover.
i need to replace the windscreen washer fuse....any help.
ty
jerryh
jerryh
Re: windscreen washer fuse location
Postby yorkshirepudding » Tue Feb 16, 2010 6:24 pm
If my memory serves me well, it's fuse 67 - behind the drop down glove box.
yorkshirepudding
Postby jerryh » Tue Feb 16, 2010 6:27 pm
thanks, but where is fuse 67, i have no diagram for fuse box.
ty
jerry
jerryh
Postby Mike » Tue Feb 16, 2010 6:39 pm
Mike
Wind up merchant!
Postby jerryh » Tue Feb 16, 2010 7:09 pm
i have tried this, but it says fuse 11 in the engine compartment, i checked this and it is fine.
from what i've read it is fuse no. 63 behind the glove compartment, but i cant find a diagram that shows this.. there is no number 63 in glove compartment.
is there anywhere to download the 2005 manual ?
ty
jerry
jerryh
Postby ake » Tue Feb 16, 2010 7:39 pm
its only fuse 67 on a Mk7 you have a Mk6, just check all the fuses, eventually you will find it
2011 Ford Mondeo 2.0 Titanium X
4 x Customs
2 x 350 MK7
7 x 260 MK7
Or is it something worse?
Postby angeleye » Tue Feb 16, 2010 10:13 pm
f11 is the fuse if thats ok ..check the pump motor ...try putting a live feed to the green /orange wire...if it works i would say the stalk is playing up..if still not working try putting a earth feed to the red /black wire on pump,..if still not working put both live and earth to pump,if not working then its the pump motor
angeleye
Postby Timbo » Tue Feb 16, 2010 10:16 pm
The wiper stalks themselves do give trouble. Make sure the connections are O.K. Check to see if you have power to the pump motor. With ignition on you should have 12 volts at both motor terminals with one going to earth when the washer button is pressed. Take the connector off the pump and connect a 12 volt bulb across the sockets. If it lights when the button is pressed then the motor is probably U/S. If not then the stalk is suspect or the wiring is chafed through at the near side inner wing. Have you CHANGED the fuse or just looked at it as sometimes you can't see the break?
Timbo
Postby johnz » Thu Feb 18, 2010 1:28 am
its in engine bay fuse box f11 book says screen washer and rear wiper its in the first row of the two longest line of fuses two rows of 9 fourth one down from relays
johnz
