FWD or RWD?
FWD or RWD?
Postby Parcel » Thu Mar 04, 2010 7:53 pm
Looking for a new Transit.
Probably a Mark 6 SWB low or medium roof
Don't know to much about the Mark 6's yet.
Would prefer a RWD as I get the impression they are more durable and easier to work on, but most of the vans for sale are FWD.
Which is best FWD or RWD?
Parcel
Re: FWD or RWD?
Postby ake » Thu Mar 04, 2010 9:13 pm
Depends what you want to use the van for, towing and heavy weight are best with RWD
2 x 67 Custom 270 Trend
3 x 66 Custom 270 Trend
1 x 65 Custom 290 Limited
7 x 12 Transit 260 Trend
1 x 60 Transit 350
Or is it something worse?
Re: FWD or RWD?
Postby Parcel » Thu Mar 04, 2010 11:22 pm
May be tow a small trailer.
Mainly large bulky stuff
Needs to be as easy as possible to maintain.
Advantage of RWD is clutch and gearbox can be removed without engine out?
Parcel
Re: FWD or RWD?
Postby Grenadekid » Fri Mar 05, 2010 12:32 am
I find from experience of our mk6 transits that the rwd is a lot more durable especially with multiple drivers but if you are the only driver its not as important. If you are pulling a trailer or thinking of heavy loads the rwd is the best option in my eyes as AKE says
At home
05 220 tdci connect (remapped to 115)
94 toyota rav4 2.0 petrol
2011 kia sportage kx3 2.0 diesel
2001 RAV4 NG
Grenadekid
Re: FWD or RWD?
Postby flyingclutchman » Fri Mar 05, 2010 7:15 am
The clutch and gearbox can also be removed without taking the engine out on FWD as well as RWD. Takes little bit longer, not that much in it.
flyingclutchman
Re: FWD or RWD?
Postby Parcel » Fri Mar 05, 2010 1:36 pm
I suppose it comes down to the question if the 2.4 is a better engine than the "Mondeo" FWD jobbie
Is it?
Parcel
Re: FWD or RWD?
Postby madmark » Fri Mar 05, 2010 2:17 pm
imo the fwd is the way to go unless you are haveing very heavy loads!
the tdci is the top one most are tddi but 100ps is probly the best all round engine! :wink:
Re: FWD or RWD?
Postby sc_BK » Fri Mar 05, 2010 2:46 pm
IMO... FWD are cheap to run and keep going on and on :)
Also lower floor in the back - easier to load, more headroom
sc_BK
Re: FWD or RWD?
Postby dametrans » Sat Mar 06, 2010 1:41 am
madmark wrote:imo the fwd is the way to go unless you are haveing very heavy loads!
WO WO are all mark 7s not tdci
dametrans
Re: FWD or RWD?
Postby ake » Sat Mar 06, 2010 8:27 am
yes, mark is referring to mk6 engines :wink:
1 x 60 Transit 350
Re: FWD or RWD?
Postby 1949bug » Sat Mar 06, 2010 10:28 am
From experience RWD is good for maintanance: ie.
Gearbox is out in a matter of minuites compared to a fwd.
much better at load carrying
Less tyre ware on the fronts
Fwd has its advantages
namley performance and MPG are better
As has been said lower floor, and an all round 'better' set up for a pannel van.
One thing I will point out a RWD transit is shockingly bad in any hint of snow/ice and even wet grass. well a pick up/tipper is anyway.
The way to look at it you need to weigh up the pros and cons and see what combination will work best for you and the work you need it to do.
The way I see it is
Pannel van (ie the normal transit) = FWD all day long.
Chassis/Tipper/dropside = RWD all day long.
Also one thing to note, if buying a RWD, make sure you dont have the 5.13 "towing" diff.
Its perfect if you pulling a digger round every day. but the lack of anything over 60mph with out the engine exploding is very annoying. Im currently changine mine to a 4.61. costing about £400 but well worth it. Something to definatly take into account with rwd.
1949bug
Re: FWD or RWD?
Postby ake » Sat Mar 06, 2010 11:00 am
Parcel wrote:I suppose it comes down to the question if the 2.4 is a better engine than the "Mondeo" FWD jobbie
Is it?
It the Mondeo which has a Transit engine, not the other way round
1 x 60 Transit 350
Re: FWD or RWD?
Postby Parcel » Sat Mar 06, 2010 11:07 am
Good point about the snow and ice, my mark 3 is hopeless in the snow. Big heavy engine at the front and no weight at the back!
I am being converted to FWD.
Is the 2.4 in the RWD jobbies related to the old Di at all? I know it is used in new Land Rover Defenders, they had to put an extra bulge in the bonnet to fit it!
And the 2.0 and 2.2 are similar to Mondeos?
Parcel
Re: FWD or RWD?
Postby ake » Sat Mar 06, 2010 12:05 pm
FWD Transits are okay in Snow as long as there isn't too much weight in the back
The 2.4 is nothing like the Di, its totally differant, The 2.0 is a smaller variation of the 2.4, and the 2.2 is an evolution of the 2.0.
The 2.0 and 2.2 used in the Mondeos are again variations of the Transit engine
1 x 60 Transit 350
Re: FWD or RWD?
Postby thunderider » Sat Mar 06, 2010 12:34 pm
is the 2.4 90ps rwd engine used in mondeos? or what else is it used in? as for anything more than mildly moist thr rwd spins ,in snow there ok once u get them going...but its getting em going !!!!!!
I am the god of hell fire.....
thunderider
