FWD or RWD?
Re: FWD or RWD?
Postby ake » Sat Mar 06, 2010 12:46 pm
thunderider wrote:is the 2.4 90ps rwd engine used in mondeos? or what else is it used in? as for anything more than mildly moist thr rwd spins ,in snow there ok once u get them going...but its getting em going !!!!!!
No, only Transits, but a variation of the MK7 2.4 is fitted to Land-Rover Defenders
Re: FWD or RWD?
Postby thunderider » Sat Mar 06, 2010 12:56 pm
5 th5n2 theres a monopoly here!! no being able to buy a mondeo for a couple of hundred quid just for the motor as oposed to a grand second hand for transit engine!!
I am the god of hell fire.....
thunderider
Re: FWD or RWD?
Postby Guy88 » Sat Mar 06, 2010 1:32 pm
for carrying weight RWD
for comfort FWD
I had a MK6 RWD SWB 330, that was a great van, snow was no probs, being RWD it wasnt as refined as a FWD but it was a brilliant drive
Now got a MK7 FWD and that is brilliant, low floor is better and the overall economy is better
2005 Ford F250 Super Duty
1992 MK3 ambulance
1980 A Series crew cab
1984 A series RB44
LIVIN' LOUD
Guy88
Re: FWD or RWD?
Postby dametrans » Sun Mar 07, 2010 12:12 am
ake wrote:
dametrans wrote:
madmark wrote:imo the fwd is the way to go unless you are haveing very heavy loads!
the tdci is the top one most are tddi but 100ps is probly the best all round engine! :wink:
WO WO are all mark 7s not tdci
yes, mark is referring to mk6 engines :wink:
i still confused, is the mk 6 tdci diferent to the mk7 tdci
dametrans
Re: FWD or RWD?
Postby winterheating » Sun Mar 07, 2010 12:23 am
yes, the tdci and tddi on mk6 are same engine but different fuel system
the mk7 engines are different to mk6's and only use the tdci common rail fuel system.
winterheating
Re: FWD or RWD?
Postby winterheating » Sun Mar 07, 2010 12:29 am
ake wrote:
Parcel wrote:I suppose it comes down to the question if the 2.4 is a better engine than the "Mondeo" FWD jobbie
Is it?
It the Mondeo which has a Transit engine, not the other way round
yeah plus the engine is far powerfull enough for a transit and more robust than the 2.4, as it has less displacement smaller stroke, less stress.
jaguar use the same engine and also
TDCi 16v ZSD ("Puma") 2.0 L (1998 cc)
2.2 L (2198 cc)
2.4 L (2402 cc)
2.5 L
3.0 L ?–? I4 turbo intercooled 16-valve DI Ford Mondeo, Ford Transit, Jaguar X-TYPE, LDV, London Taxi TX1 & TXII, Citroen Jumper, Peugeot Boxer, Fiat Ducato
the 2.2 duratorque is a 2.0 engine with a 2.4 crank fitted.
winterheating
Re: FWD or RWD?
Postby winterheating » Sun Mar 07, 2010 12:32 am
thunderider wrote:5 th5n2 theres a monopoly here!! no being able to buy a mondeo for a couple of hundred quid just for the motor as oposed to a grand second hand for transit engine!!
mondeos that have the tdci engines cant be used really as the pistons are different to the tddi ones, if you know of any mk3 mondeos that are only couple of hundred then let me know please :wink:
and the fwd engines are only £600 rather than a grand for 2.4 rwd. which you cant get in mondoes, but can in ldv's.
Last edited by winterheating on Sun Mar 07, 2010 12:33 am, edited 1 time in total.
winterheating
Re: FWD or RWD?
Postby Gavin » Sun Mar 07, 2010 12:32 am
i was looking at mk6's on autotrader recently and lots of the cheap FWD's had goosed diesel pumps, and they were only showing 120-140,000 miles........never seen a mk5 advertised for sale with a broken pump....my W reg is still plugging away at 150k without a hitch, but the rest of the van is falling apart around the motor....is it more of a problem on the newer engines?
Gavin
Re: FWD or RWD?
Postby winterheating » Sun Mar 07, 2010 12:37 am
Gavin wrote:i was looking at mk6's on autotrader recently and lots of the cheap FWD's had goosed diesel pumps, and they were only showing 120-140,000 miles........never seen a mk5 advertised for sale with a broken pump....my W reg is still plugging away at 150k without a hitch, but the rest of the van is falling apart around the motor....is it more of a problem on the newer engines?
thats because of cost, if the mk6 could be fixed for £50 like the 2.5di then they wouldnt be up for sale.
modern pumps are more fussy about good fuel.
my pump lasted 180k and is on a mates van now running fine.
winterheating
Re: FWD or RWD?
Postby thunderider » Sun Mar 07, 2010 7:23 am
i think pumps seem to have a life span of about 3 years or 120-180,000 miles,based on my own observations,the first pump on my first engine went at 3yrs 180,000 mls,had it reconned,then was knacked at 289,000,so had a new pump on the engine wich has just failed at 3years and 140,000mls,but pricey beasts,the last one was £1,050, that was supply fit with a new pipe from the fuel filter,this was from carwoods in smethwick.
thunderider
Re: FWD or RWD?
Postby Gavin » Sun Mar 07, 2010 12:16 pm
a grand for a pump? :shock: maybe i'll buy a cheap mk6 with a dud engine and sling the di from my smiley in it! :lol:
Gavin
Re: FWD or RWD?
Postby squiddly » Sun Mar 07, 2010 12:38 pm
morn everyone :)
is there anyway you can tell.. if the pump is on its way out? and can you get a fwd with a lwb and a hi top,I want a van but its like a mine field out there lol.
squiddly
Re: FWD or RWD?
Postby GBBiker » Sun Mar 07, 2010 12:47 pm
1949bug wrote:One thing I will point out a RWD transit is shockingly bad in any hint of snow/ice and even wet grass.
Must be your driving style :wink:
I've never had any problems in RWD Transits :P
GBBiker
Wrong Again!
Re: FWD or RWD?
Postby GBBiker » Sun Mar 07, 2010 12:53 pm
winterheating wrote:3.0 L ?–? I4 turbo intercooled 16-valve DI Ford Mondeo, Ford Transit, Jaguar X-TYPE, LDV, London Taxi TX1 & TXII, Citroen Jumper, Peugeot Boxer, Fiat Ducato
The LDV Maxus, Citroen, Peugeot and Fiat don't use the Ford engine :?
They have a Fiat 3.0l intercooled JTD engine :wink:
In fact, LDV haven't used Ford engines since the Maxus was born and the last Convoys and Pilots ran off the production lines. They are all Fiat engines since then :wink:
GBBiker
Wrong Again!
Re: FWD or RWD?
Postby winterheating » Sun Mar 07, 2010 1:56 pm
where do I say ldv maxus :?: :?:
http://www.google.co.uk/url?sa=t&source ... 140GmbjAcg
http://www.google.co.uk/url?sa=t&source ... krPMy4h7Tg
http://www.google.co.uk/url?sa=t&source ... OgoSz0eBfA
http://images.google.co.uk/imgres?imgur ... s%3Disch:1
you will have to translate the last one.
winterheating
Users browsing this forum: Bsu68, Majestic-12 [Bot]
