jacko1611 wrote:recently our ids computer software has been playing up when re setting speed limits through the service functions menu, which is the quick way. i bet this is what they have tried to do. if they go into vehicle program parrameters, which brings up all the different options the van is equipped with they will be able to select no speed limiting from there. Had to do this quite a few times now.
dametrans wrote:i have re rated my mk 7 minibus from 15 seater to 9 seater therfore i can remove tacho and speed limiter, today i went to ford dealers and 3 times they programed it with no limit, however it was still limited 100kilom or62mph, when i took it on road, help please, i should also note that when i even disconnected the tacho it made no diffference
dwright2104 wrote:dametrans wrote:i have re rated my mk 7 minibus from 15 seater to 9 seater therfore i can remove tacho and speed limiter, today i went to ford dealers and 3 times they programed it with no limit, however it was still limited 100kilom or62mph, when i took it on road, help please, i should also note that when i even disconnected the tacho it made no diffference
The law is for vehichles with 8 or more passenger seats, it is not law for a limiter to be fitted to transits, but 100km/h is still a speed limit for vehichles with 8 or more passenger seats.
So the max seats you can have to exceed 100kmph is 8 including driver.
jacko1611 wrote:ids computer should say that the new file has been loaded but only real way is to go up the road
robsbird wrote:ha ya tryed doing 70mph in dublin you mine the pot hole's they have only just worked out how to build a motorway
grollie wrote:Spent time in both places. When in Dublin most of the M50 was 50klicks (31mph). In leamington you forgot about thetaxi drivers. almost as bad as Brum?
Mikey B wrote:Did one of these in work on friday went into car config and changed it through there, No problems what so ever.
All the ones i have done have worked without a hitch to be honest.
Users browsing this forum: Google Adsense [Bot], Majestic-12 [Bot]
