thunderider wrote:blimey you were both right!!
Andyg wrote:Low pads
Phil_G wrote:Andyg wrote:Low pads
Leaky slave cylinder?
Ive never had a set of pads go so low that the fluid warning light came on on anything Ive owned. Tbh, Ive never heard of it either. Loss of braking performance/ a change in pedal feel can be a gradual process, rendering it hard to spot unless you drive more than one of that particular model.
Worth a shufty about as with it being a weight bearing commercial vehicle, braking performance is a key point.
