break warning lite
break warning lite
Postby thunderider » Sat Jul 01, 2006 2:45 pm
on the dash keeps flickering on and when i go aroud corners and islands,the breaks are ok cuz i aint crashed yet!!
I am the god of hell fire.....
thunderider
Postby motorwise » Sat Jul 01, 2006 3:47 pm
check your fluid level it's probably low
http://www.motorwise.net
motorwise
Postby Nighthawk » Sat Jul 01, 2006 4:02 pm
yup, low fluid level
:D
Transit.........Job done
Nighthawk
Postby thunderider » Mon Jul 03, 2006 10:58 pm
blimey you were both right!!
thunderider
Postby motorwise » Mon Jul 03, 2006 11:03 pm
thunderider wrote:blimey you were both right!!
don't sound so surprised :lol: :wink:
motorwise
Postby Phil_G » Mon Jul 03, 2006 11:44 pm
Now to find out where the lost fluid went....
Phil_G
Postby AndyG » Mon Jul 03, 2006 11:51 pm
Low pads :?: :idea: :roll:
Postby motorwise » Mon Jul 03, 2006 11:54 pm
Andyg wrote:Low pads :?: :idea: :roll:
thats my guess as well :D
motorwise
Postby Nighthawk » Tue Jul 04, 2006 8:39 pm
I'm often right, except when it's a dialogue between myself and the wife, then i'm ALWAYS wrong :shock:
Low pads would be my guess, if it were down to a leak it'd have affected the brake performance in some way be it lost effort through fluid contamination or a soft pedal through fluid loss.
Nighthawk
Postby Phil_G » Tue Jul 04, 2006 9:51 pm
Leaky slave cylinder?
Ive never had a set of pads go so low that the fluid warning light came on on anything Ive owned. Tbh, Ive never heard of it either. Loss of braking performance/ a change in pedal feel can be a gradual process, rendering it hard to spot unless you drive more than one of that particular model.
Worth a shufty about as with it being a weight bearing commercial vehicle, braking performance is a key point.
Phil_G
Postby motorwise » Tue Jul 04, 2006 10:00 pm
very common Phil - garages see it a lot
motorwise
Users browsing this forum: blue estate, Majestic-12 [Bot], Totty79, tranmx2
