by yellowcamper » Sat May 26, 2018 12:02 pm
Thanks guys.
I will have another look tomorrow, I did see a plug in the rear light cavity, but discounted it as it was only 2 pin.
Twice previously (Vauxhall Senator and Land Rover Discovery) I found a small 7 pin plug so was keeping an eye out for one of them.
I had another look at the Haynes Manual and it appears there is a dedicated fuse in the engine bay for a trailer connection, but I was hoping to avoid removing trim to thread a wire all the way through the vehicle. If the two pin connector is there and ignition controlled that will be brilliant.
I did some more reading and an American site seemed to say you have 3 60A connectors if a twin battery and one if a single. I have three so as I only have one battery I think it is safe to assume it has had two at some point and when all the AA wiring was removed a battery was removed too. At least I can put another one under the seat for all the camper stuff, LED Lights, 12V/USB in the rear, Water Pump. As far as I can see as long as it has a fuse I can connect the positive of the camper battery to the 60A points through a Voltage Sensitive Relay. It only cuts in at 13.3 V and cuts out at 12.65V so the two batteries will be separate if the engine is not running.
Looking at the wiring diagram, the standard factory two battery set up seems to be similar in that it shows a relay that seems to protect the start battery from drainage by accessories, but not knowing what is or isn't there In my vehicle to begin with that seems to be the easiest approach.
I will post up on the Yellow Camper thread when I get it up and running.
Thanks again.
Sean.
