Vehicle Carrying Weight Capacity
Postby workinprogress » Mon Aug 30, 2010 4:26 pm
Hello everyone, new to the forum. Thought I'd join up as I've just got a '55 plate Transit car transporter, T350 90.
I'm curious regarding the weight the vehicle can transport, it has the following weights on the VIN plate, passenger side B pillar: -
3500Kg
5750Kg
1600Kg
2450Kg
Can anyone shed some light on what these mean?
Cheers
workinprogress
Re: Vehicle Carrying Weight Capacity
Postby madmark_50484 » Mon Aug 30, 2010 4:36 pm
3500KGS GVW
5750KGS GTW
not sure about the other weights
GVW is the total weight including the truck and anything on it
GTW is the total weight including towing.
what you need to do is fill up with fuel put everything you normally carry on the truck take it to your local weighbridge whatever it comes up with minus it off 3500KGS then you will get how much you can carry.
Past
MK5 98 R reg Transit 190 LWB Semi hi Top
Mk5 98 S reg Transit 190 LWB High Cube
Present
Mk5 96 N Reg Transit Luton
Forum for bus enthusiasts and preservationists
www.busesuk.co.uk
madmark_50484
Postby knighty1981 » Mon Aug 30, 2010 5:27 pm
3500Kg max van weight
5750Kg max weight of van + trailer
1600Kg max front axle weight
2450Kg max rear axle weight
knighty1981
Postby workinprogress » Mon Aug 30, 2010 7:20 pm
knighty1981 wrote:3500Kg max van weight
Cheers guys! So 3500Kg would be the maximum weight it could be including the weight of the truck and the car it's transporting?
workinprogress
Postby knighty1981 » Mon Aug 30, 2010 7:29 pm
^^^ yes :-)
knighty1981
Postby (ROG) » Mon Aug 30, 2010 7:50 pm
Including the weight of the driver as well - in fact ...... EVERYTHING
If unsure if it is overweight then you can legally drive directly to the nearest weighbridge (client must pay) and if overweight then you can legally drive directly back to where it was loaded to have it sorted out.
EX IAM car and commercial observer
(ROG)
Users browsing this forum: Bsu68, Majestic-12 [Bot]
