Following on from a previous posts where a faulty EGR valve was mentioned, I've undertaken a load of reading and now have some further questions.
Sypmtoms:
Twice now, at the start of a jouney (<15m) - the engine has lost all power when pulling off, so low RPM. Causing, or almost causing a stall. This has quickly cleared with a "pinking" type noise and some black smoke. Both times this has happened it happened in quick succession and then been fine thereafter.
In all other respects the engine feels like it is working perfectly.
The Engine
The van is a Transit Mk6 FWD SWB 280 125 engine. 39,000 miles, pretty much unthrashed and gentle drivers though laiden all its life(campervan)
The EGR Valve
I understand the EGR valve is typically closed, and opens on a vaccum to allow exhaust gas to be recombusted for emissions only. I understand MOT doesn't detect a failed/blocked valve as the RPM/vaccum isn't high enough.
Questions
1 - So the EGR valve is normally closed, why would it try and open when pulling off, e.g. at low RPM? Doesn't it open at high RPM?
2 - Does the EGR stick closed or open? Why would a sticking valve cause the symptoms I had? Too much air going in? Too little? I'd expect "stick open & too much air/dirty air" being the problem, as stuck closed should just get fresh air? But why does it tick over fine and only play up when I try to pull off?
3 - Some EGRs are vaccum only, some electronic - any idea which mine is?
4 - Is the picture showing my EGR!
5 - Some people say to block off the vaccum pipe, e.g. kink & cable tie. Is mine suitable for this mod, and is the pipe the one I highlight?
6 - How easy is this to remove and clean? Any gaskets need replacing? I'd prefer to know how to just in case I need to when I'm in the middle of nowhere.
7 - If the "kink pipe" trick is applicable on my van variant, and stops the EGR working, then does it stay open or closed? And according to http://www.parkers.co.uk/advice/forum/t ... C_ID=14421 it suggests problems with it stuck either open or closed? Errrr.....
8 -Finally - any idea of replacement cost (parts/labour?)
Anyway - pics of my engine and, what I think is the EGR valve and pipe are attached below. Whilst I am a logical person and a reasonable DIYer - I've never come across EGR till the previous post.
Many thanks for your help.
