Frozen engine
Frozen engine
Postby mattcat » Sun Dec 05, 2010 4:41 pm
Hi all, got a frozen engine 03 diesel, had a coolant leak and was filling up with water, van was sitting 4 days no useage and weather hit -8, I went to start it and she wouldn't fire.
I defrosted the pipes I could get to and got the jump leads out, but still wouldn't go.
The starter is trying to go but engine not kicking in.
Got the aa out and after trying to jump with his battery he said the timing belt has snapped( spent 2 mins at the van and didn't take anything off to look).
Could the water pump be jammed frozen too?
My mechanic mate says to let it thaw right out and try it again as there is no timing belt on these, its a timing chain and they very rarely snap.
The engine hasn't started at any time since the freeze and was working fine beforehand.
Any advice please, Cheers.
mattcat
Re: Frozen engine
Postby dodgy01 » Sun Dec 05, 2010 4:44 pm
as your mate says let the whole thing thaw out and cross your fingers
dodgy01
Re: Frozen engine
Postby cossie7 » Sun Dec 05, 2010 5:09 pm
You could try taking the drive belt off for the water pump so when your cranking it it's not trying to turning the water pump when turning. This may help tell you if it's the water pumpthats frozen. If it starts don't let it run to long as the water won't be circulating with out belt on
ID RATHER PUSH A TRANSIT THAN DRIVE A SPRINTER!!!
cossie7
Re: Frozen engine
Postby mattcat » Sun Dec 05, 2010 5:42 pm
Is the drive belt easy to get off the water pump :?
How do you go about it
mattcat
Re: Frozen engine
Postby cossie7 » Sun Dec 05, 2010 8:42 pm
Is it a 2.4 or a2.0? As the 2.4's are on one big serpentine belt and the 2.0's are a separate belt all together?
cossie7
Re: Frozen engine
Postby Guy88 » Sun Dec 05, 2010 8:51 pm
that AA mans a t**t, there aint a timing belt on these, :roll:
2005 Ford F250 Super Duty
1992 MK3 ambulance
1980 A Series crew cab
1984 A series RB44
LIVIN' LOUD
Guy88
Re: Frozen engine
Postby ChuckH » Sun Dec 05, 2010 8:53 pm
Do not attempt to start the engine until its thawed out There is NO point !!! You could try getting one of those parrafin heaters used in greenhouses and put it under the sump And wait !! If its that frozen though the chances of having done no damage are practicly nill !
Why no Antifreeze ?????
ChuckH
Re: Frozen engine
Postby bigjohnthomas » Sun Dec 05, 2010 9:03 pm
i have a "friend" :oops: who froze a 2.4 last year that wouldn't turn over till "he" jumped it then it turned out that the drive to the impella in the water pump got sheared new pump on and all was well for a month or so then it developed a hole in the block :shock: :(
Bum holes
bigjohnthomas
Re: Frozen engine
Postby mattcat » Sun Dec 05, 2010 10:28 pm
Its a 2.0 litre engine and there was no anti-freeze as it had a bloody leak and just not had time to get it fixed.
As the song goes "If I could turn back time".....................
Anyone know when the next thaw is in Scotland, May or June!!
mattcat
Re: Frozen engine
Postby ake » Sun Dec 05, 2010 10:51 pm
mattcat wrote:Its a 2.0 litre engine and there was no anti-freeze as it had a bloody leak and just not had time to get it fixed.
July :wink: Get some heat on it, couple of fan heaters, let it thaw then try and start it, when it does warm it up then drop the water and refill with 50/50 Antifreeze mix
2 x 67 Custom 270 Trend
3 x 66 Custom 270 Trend
1 x 65 Custom 290 Limited
7 x 12 Transit 260 Trend
1 x 60 Transit 350
Or is it something worse?
Re: Frozen engine
Postby mattcat » Sun Dec 05, 2010 11:07 pm
Thanks for replys.
I'll keep you posted, think we might be getting a high of 3 degrees C Thursday :)
I might give it a blast before hand if I can get a half decent heater into it!
I so hope that aa guy was in a hurry and couldn't be arsed (Sunday morning 10am and stinking of drink)
Fingers crossed.
Thanks again.
mattcat
Re: Frozen engine
Postby thunderider » Sun Dec 05, 2010 11:16 pm
got any were to store it as it would be better to get it in side n get a big heater in there
I am the god of hell fire.....
thunderider
Re: Frozen engine
Postby knighty1981 » Mon Dec 06, 2010 12:03 am
first thing to do is take the bottom pipe off the radiator
that way, if it starts to defrost it can leak out, instead of just re-freezing the next night !
if you get it to start with the water pump belt off (still with bottom pipe of the radiator) run it for 1min and then shut it off, give it a couple of min and then do the same again.... keep doing that to warm it up and defrost it ;)
knighty1981
Re: Frozen engine
Postby funkeyfarmer » Mon Dec 06, 2010 12:51 am
No experience of this myself thank god but was just reading about it on an other site sone intering points if you you want a look http://farmingforum.co.uk/forums/showthread.php?t=42751
funkeyfarmer
Re: Frozen engine
Postby cossie7 » Mon Dec 06, 2010 9:29 am
On the 2.0 the water pump belt is on your right hand side of the engine if your stood facing the front of the van with the bonnet open. It's a single belt ran off the front cam on a tensioner. Just back the spring loaded tensioner off and pop the belt off simples
cossie7
Users browsing this forum: Majestic-12 [Bot], WarthogARJ
