paul. wrote:Hey, my first transit and im wondering is how many miles will they do before they cost more to fix than to buy a new one.
trigger wrote:Last as long as you want it to with the right care and maintainance
DEAN MACHINE wrote:i think they start to show a bit of wear after 250,000 but thats just everyday motorway buisness use ,for private,social use good for 350,000 i think
solarman wrote:DEAN MACHINE wrote:i think they start to show a bit of wear after 250,000 but thats just everyday motorway buisness use ,for private,social use good for 350,000 i think
have been told if well maintained and serviced 3-400000 miles,
Solarman.
paul. wrote:the only problem is i got it at 197,000 so i cant say if it was abused
winterheating wrote:paul. wrote:the only problem is i got it at 197,000 so i cant say if it was abused
theres always two choices, run it with very little maintainance to save on money, and risk expensive repairs and run not at full potential and less efficient.
or look after it keep an eye on levels, cost a bit more to maitain, but far less risk of expensive breakdown, and will be nicer to run and more efficient.
if its ok now, then look after it and should be fine.
main things to watch for, regular oil change with correct decent oil. oil and fuel filters regular, also check water drain on fuel filter, injection systems can last very high miles as long as looked after aswell. good fuel also helps.
Make sure correct amount and type of antifreeze/coolant is in to protect all alluminium parts correctly, like eg cooler, oilcooler, heater matrix, Radiator,cylinder head and water pump.
Timing tensionor and maybe guides should be changed like you would a cambelt, EGR should be blanked, inlet cleaned as they cause more engine wear and make run less efficiently, there just to lower emmissions.
