The story...
Today My 51plate FWD set off as normal (not from cold), 1st, 2nd, then I couldn't get 3rd so I rolled down the hill for a while trying for 4th.
Finally found 4th and was able to use 3rd and 4th, I pulled over for a phonecall and it got stuck in 5th (couldn't get reverse at this stage though).
Found my way back into 3rd and settled for 3rd and 4th as they'd get me home.
Basically it's stuck in 3rd and 4th, the clutch seems fine (for now), I was warned about a slightly dodgy syncro some time ago but I don't think that's the problem as each gear works if I can find it. I also heard somewhere, it could be ingress of moisture in the selector turret. I'm just hoping it's nothing more serious.
I have more time than money at the moment so I'm going to have a go at sorting it tommorow, unless someone against this and parts are affordable.
Some things i've heard I should try are..
-making sure the water pump isn't frozen and there is coolant. (not sure I understand why but it's worth doing anyway)
-checking the cables are moving/working (what cables do what?)
-checking the cables are properly crimped at the end
-disassembling the gear selector turret and making sure everything is in order, grease, then sealing it? ...
Would anyone be able to improve on this rough checklist or offer a brief step by step of what I should be checking and in what order? It's cold so i'd rather not waste my time checking the wrong things. I'd really appreciate it.
Thanks, Rob
