MK5 Clutch
MK5 Clutch
Postby Wreckersinternational » Wed Dec 29, 2010 8:17 pm
It's getting difficult to get into first gear (clutch dragging?) Is it likely to be the clutch itself or the auto adjuster?
Re: MK5 Clutch
Postby john leeman » Wed Dec 29, 2010 9:02 pm
Auto adjuster could give trouble, or clutch arm, they develop cracks & bend, or clutch cable, the outer cable crushes together loosing movement. Good luck, let me know how you get on. John L.
35 years of driving,repairing,sleeping in transit's lovin every minute.
john leeman
Re: MK5 Clutch
Postby transit nut » Fri Dec 31, 2010 11:38 am
Ive a Mk5 and ive had to change the clutch twice in about 6 years. Both times i found the arm was faulty so it needed a new clutch and arm.
Mine hasnt got an auto adjuster, its inside the van above the pedel
Good luck n i hope this helps ATB Mark
transit nut
Re: MK5 Clutch
Postby MinorMatt » Fri Dec 31, 2010 12:13 pm
The auto adjuster ratchet arrangement was fitted until '97
Lucas Laser 2000 & IDS
93 L GL Minibus
96 P 150 TD 100PS LWB Hi-Top
