Tipper wont come down
Re: Tipper wont come down
Postby Rustyw777 » Fri Feb 26, 2016 8:20 pm
Is it a lowering soliniod your talking about?? If so I've just replaced it
Rustyw777
Postby Frag » Fri Feb 26, 2016 8:24 pm
Nope.
It's purely a limit switch, on or off,body raised or lowered.
Has a rubber boot over a plunger,2 wires to it.
Frag
Ford Technician
Postby Rustyw777 » Fri Feb 26, 2016 8:27 pm
If your on about the soliniod then I have just replaced it with a new one but the problem still persists. Or is there another switch
Rustyw777
Postby Frag » Fri Feb 26, 2016 8:31 pm
It's not a solenoid,
Nowhere near tipper pump or motor.
It's mounted on the frame that tipper rests on when fully down,just at back of cab.
It tells the control box on dash if body is raised or lowered fully.
When van was new,there would have been a VFS tipper manual with it showing a pic and listing all parts also...
In glovebox.
No doubt that's long gone.
Frag
Ford Technician
Postby Rustyw777 » Fri Feb 26, 2016 8:32 pm
Do you have a link to a picture so I can locate it the solenoid I have for has two wires with a rubber boot and a nylon hat that the body/bed shuts on to
Rustyw777
Postby Rustyw777 » Fri Feb 26, 2016 8:54 pm
I think we are talking about the same thing. The Bloke at VFS called it a solenoid
Rustyw777
Postby oldwoodcutter » Fri Feb 26, 2016 10:18 pm
Ive found the fellow at vfs very knowledgable and helpful when my tipper stops going up or coming down.
oldwoodcutter
Postby Anthonymark1986 » Mon Nov 20, 2017 2:50 pm
I just had the same problem tipped some
Hardcore off and wouldnt go back down but would go up more, i had to undo a nut with two wires on to let it down slowly, now i am stuck with when the lowering solanoid arrives which is what i believe it to be, how do i get the bed back up, will it have enough fluid to get it back up
Anthonymark1986
