Mk 7 fuel filter change advice required
Postby RacinRob » Wed Feb 09, 2011 10:29 am
Due to give the van a service this Friday. It's the first time I have serviced the transit - but have spent too long fixing my motors/bikes.
Only point of concern is changing the fuel filter - anything I should look out for?
What's the standard procedure?
Van is a T260-85 fwd.
Cheers
Rob
RacinRob
Re: Mk 7 fuel filter change advice required
Postby DEAN MACHINE » Wed Feb 09, 2011 11:27 am
RacinRob wrote:Due to give the van a service this Friday. It's the first time I have serviced the transit - but have spent too long fixing my motors/bikes.
Cheers
Rob
make sure the filter is full to the brim of diesel before refiting
DEAN MACHINE
Postby uksoftware » Wed Feb 09, 2011 3:09 pm
This might not apply to FWD version but I find my MK7 RWD filter very hard to locate just right. You have to give it a good SHOVE upwards once you`ve aligned the markers.
When you pull your old filter down, make a mental note of the notches and where they are.
uksoftware
Postby RacinRob » Wed Feb 09, 2011 4:17 pm
The filter is still sitting in the box - I will have a look at it tonight.
Good tip though because the previous merc filter screwed on!!!!
RacinRob
Users browsing this forum: Aidanb, BeauTB, man le-mans
