EGR Valve, How to blank off?
Postby myfiestast » Fri Mar 11, 2011 7:51 pm
i know this seems to be a common topic but im finding it hard to find a sort of mini guide of how to blank it off! im gonna do this asap as really pissing me off now as keeps putting van in limp mode!
so if someone can help would be great!
mk6 Jumbo 2.4 125 T350 528k
mk7 Jumbo 2.4 140 T350 265k
myfiestast
Re: EGR Valve, How to blank off?
Postby ake » Fri Mar 11, 2011 8:31 pm
You need to replace your faulty egr valve and insert a blanking plate to prevent the exhaust gas passing thru it
2 x 67 Custom 270 Trend
3 x 66 Custom 270 Trend
1 x 65 Custom 290 Limited
7 x 12 Transit 260 Trend
1 x 60 Transit 350
Or is it something worse?
Postby myfiestast » Fri Mar 11, 2011 9:02 pm
so i cant just block off the one already fitted?
myfiestast
Postby MrMPuk » Fri Mar 11, 2011 9:04 pm
myfiestast wrote:so i cant just block off the one already fitted?
No because it will still be defective and bring up the fault.
Postby Felixx » Sat Mar 12, 2011 4:19 pm
:?: If you blank a working EGR valve,will it show an EML on the dash?.The reason I ask is that I have a Vectra CDTI,and when they are blanked they show the EML warning on the dash. FELIXX. :)
Felixx
Postby angeleye » Sat Mar 12, 2011 4:22 pm
only mk7 will show if its a mk6 it wont
angeleye
Postby TIMO » Sat Mar 12, 2011 4:22 pm
It does on a mk7
mate
BBC = British Broadcasting Conspiracy
http://www.youtube.com/watch?v=nj82wxnO ... r_embedded
TIMO
Postby angeleye » Sat Mar 12, 2011 4:23 pm
myfiestast wrote:i know this seems to be a common topic but im finding it hard to find a sort of mini guide of how to blank it off! im gonna do this asap as really pissing me off now as keeps putting van in limp mode!
there is a guide on here for a mk6..have alook in the technical how to section
angeleye
Postby Felixx » Sat Mar 12, 2011 7:04 pm
TIMO wrote:It does on a mk7
mate
I take it the Mk7 is a common rail diesel with all the usual associated sensors?.What year does the Mk7 run from?,as mine is a 2000,2.4 DI,but registered in October 2001. FELIXX. :?:
Felixx
Postby angeleye » Sat Mar 12, 2011 7:54 pm
mate
yours would be a mk6 and can be blanked with out putting light on
mk7 from (think) second half of 2006 onwards
angeleye
Postby psv-hgv-flt » Sat Mar 12, 2011 8:32 pm
2.4 no probs.
:wink:
psv-hgv-flt
Postby Felixx » Sat Mar 12, 2011 9:16 pm
mate
Thank's for that,I think I might do that mod.Are there any negatives to blanking on the 2.4 ?,as on my Vauxhall Vectra CDTI,because of the inlet manifold design,I've vented the Crank Case to atmosphere and semi blanked the EGR.This reduces the amount of soot and oil mist,(in the crank case fumes),from combining and "crudding up" the manifold.Is there any thought on crank case ventilation,or the use of catch tanks on the Transits?.Would be interested in finding out. FELIXX. :D
Felixx
Users browsing this forum: Bing [Bot], Google [Bot], martin1vol
