right i did this on sunday morning so a rough guide if anyone has to do it
1st , i removed the pipe from on top of the water pump (out pipe from matrix) collect the coolant unless you want wet feet
2nd,you need to remove the cover on the blower box with 3 pozi screws in it just above and left of the clutch pedal you will see 2 pipes and a rubber hose that go through a rubber square and then through the bulkhead
3rd,i cut the pipes from the matrix here,then you can pull the matrix out towards you (this way its easy to unclip the hoses)
4th,you can now pull the heater hoses out from under the bonnet and release the quick release clips from the matrix pipes easily with a small screwdriver(just push the 2 white tabs under the black pipe end)
5th , you need to unscrew the 4 bolts that hold the blower + box in place (there is 2 10mm bolts either side near the top and about 4 inches below)this gives enough room to move the box about , you may want to remove the radio if you still have the double din ford radio as the box needs to go up a bit
6th, i got a tyre lever(you could use a bit of timber) underneath the blower box against the floor and levered the blower box towards the passenger seat(up and backwards) then you can slide the new matrix back in you will prob need to depress the clutch to clear the pipes the last inch or so into the blower box as it is a bit of a pain (this bit needs a bit of pushing and pulling and i removed the 2 poxi screws that held the cup holder in place then bent the plate behind it out a bit then back in afterwards )
7th , replace the 4 bolts on the blower box and the 2 hoses push back on under the bonnet ,i cut the rubber square against the bulkhead and slid it through the pipes from the matrix through the bulkhead (as there is a breather pipe runs through the rubber square dont forget),replace the plastic cover ensuring the pipes dont touch the sides,replace the hose back onto the top of the water pump and top up with water/coolant (i also replaced the thermostat (6 quid from ebay ) and flushed the rad while i was at it and then its all done
took me about 3-4 hours but was well worth it and no more coolant smell and steamy windows
worth a little drive and top up with water/coolant after (remember what colour mix you coolant is)
seemed a little daunting to start with but with patience it can be done even by an amateur like me!
if anyone is stuck you can pm me
cheers
andy
