2.4 TDCi H9FA, H9FB, & H9FD Engines
Postby ECROZ » Fri Nov 11, 2011 9:12 pm
Hi again folks,
Looking for engine measurement & machining limits for the above engines
(factory engine w/shop manual would be great)
Have 2 failed H9FB engines and the customer wants me to try & make them in to 1 good one as a spare for his fleet
One has spun a main the other has destroyed the top end
Unable to find the information through my normal engine machinists as they haven't either done one b4 or got any data on them
Hoping to obtain the information so we can do the job together
A long bare engine from Ford is over $14,500.00 here :!:
Thanks in advance
ECROZ
Never assume anything that just makes an ASS of U and ME
ECROZ
Re: 2.4 TDCi H9FA, H9FB, & H9FD Engines
Postby winterheating » Fri Nov 11, 2011 9:28 pm
Basically all the same.
lower powered ones dont have the oil splash nozzles under pistons.
cranks all the same
quite a few different rods and pistons, for all the engines.
well 3 for 2.0 3 for 2.4's
This determins the 3 differnet Head gasket thicknesses required.
3 different sizes of pistons A,B,C i think. Which can be for any of the engines.
All cams the same for each engine.
As you know timing sprockets can differ, chain etc.
This is for tddis the tdci engines do have a couple of differences.
Actually im sure ive posted all the info before ill look for it.
winterheating
Postby winterheating » Fri Nov 11, 2011 9:49 pm
Theres a bit here on the differnt piston and rod sizes.
viewtopic.php?f=5&t=83532&hilit=piston+sizes
winterheating
Postby Guy88 » Fri Nov 11, 2011 10:00 pm
would probably be easier to use a good bottom end and fit the head onto it,
2005 Ford F250 Super Duty
1992 MK3 ambulance
1980 A Series crew cab
1984 A series RB44
LIVIN' LOUD
Guy88
Postby ECROZ » Fri Nov 11, 2011 10:28 pm
thanks for the info
I unloaded them about a month ago and left them in the corner of the workshop (came to me stripped & in boxes)
Was gonna do as you say use the good bottom end with the good head, but really want to measure bores, crankpins, etc b4 i get too involved as if a lot of machining is reqd might not be cost effective.
I can source imported long bare engines for a fraction of the Ford price
But would be good to do to familarise myself & my machinists with the engine
This is a back burner project, but need the technical info/measurements so I can advise customer
ECROZ
Postby winterheating » Fri Nov 11, 2011 11:03 pm
All heads are the same even a tdci could be used for a tddi, but not the other way round because of the cam sensor on a tdci.
winterheating
Postby winterheating » Fri Nov 11, 2011 11:09 pm
Main thing to watch out for is double check the hg thickness for what conrods are fitted.
And the correct size piston thats it really....
Also what to watch for is there is 2 different front crank seals to go with a 2 different timing covers.
There is a free download of the Ford Technical info on all the engines somewhere, shows all dimensions that differ and what doesnt.
winterheating
Postby winterheating » Fri Nov 11, 2011 11:15 pm
Here, loads of good info in there when you look through, and get the hang of it.
http://isohunt.com/torrents/?ihq=ford+tis+2004
winterheating
Postby ECROZ » Sun Nov 13, 2011 7:54 am
winterheating wrote:Here, loads of good info in there when you look through, and get the hang of it.
Thanks for that winterheating had a few download & burn issues initially but all OK now :wink:
Any updates anywhere TSB's are way old :(
ECROZ
Postby winterheating » Sun Nov 13, 2011 2:43 pm
No unfortunately ther doesn't appear to be any available than this one yeah it is old but does help a lot.
You can just use Microsoft word to copy from it to clipboard.
If you need any further info on the tdci system, there is more in depth in the transit connect section
takes a bit of searching for different things but it is all there..
winterheating
