When I first got home after breaking down I did find the pipe not to be as tight as I expected
I tightened it further but to no avail
I removed the pipe but there was no obvious sign of damage so I refitted it hoping that might cure it, sadly no
ill ring my local ford dealer tomorrow and see what if any stock they have, I must admit they are normally quite good
ill also ask if its a high stock turnover part if its in stock, ill keep you informed
I must admit the fuel mpg so far is better than the std 90 ps vans I have driven or hired, the first full prior to a ford parts and oil service I gave it was 37.7mpg after the service (air filter was black) it was 41.7mpg
with the aircon on too and it goes like a rocket
Transit Custom Limited H1 L2 DCIV, now converted to van by removing the seats etc so now twin side loading doors, fully kitted out with Sortimo racking, always loaded to capacity & averages 35mpg
