Hi guys, new here but hoping for some help.
I have a 55 plate connect and at the ring at ignition barrel has got a broken connector for the wires, I tried to solder the wires on direct as the green connector was broken but had to trial and error the cables to get them in the correct order. Now all soldered up but I am still getting the quick flash of the led on the dash and nothing seems to be happening. Desperately looking for a fix ASAP for this. I am hoping that during my trial and error placements of the cables hasn't somehow damaged the pub in the module attached to the ring. Any help would be very much appreciated. Even if there is a temp bypass solution just to get it going for now as it's my work van,
Thanks in advance
