OldskoolUpNorth wrote:Done a lot of research on this now.
It could be down to a few things but most likely it is the cluster itself.
Ford apparently know of the fault and would replace the cluster for £99.00 but that has now finished.
Trying a few fixes and will post results if and when I have some.
Neil.
Graham Taylor wrote:OldskoolUpNorth wrote:Done a lot of research on this now.
Neil.
If it is the cluster then you can get it repaired for less than £99. Google Ford Connect Cluster repairers and hopefully you'll find one near you and maybe repair it while you wait.
nardi wrote:
I'm afraid that you can't replace it because the immobiliser is built in to the cluster itself .And many tried repairing but no luck.It must be something else.
Frag wrote:Could you not wire meter up,so it can be seen in cab and monitor it while driving,
So you can see what happens when it faults..?
