Anyone know why the clutch slave hose would pop off here?
Could it be the slave is stuck?
2004 Connect with 150k on the clock
Just fixed the fuel pump, now this! Need the wife back in business asap, planning to disassemble tonight & fit new slave tomorrow. Tried to reconnect and bleed but fluid going nowhere pushed up from the slave.bleed nipple by an Easibleed with 20psi pressure. Help!
