90ps connect vs 90ps focus, what happened??
Re: 90ps connect vs 90ps focus, what happened??
Postby paul2012 » Sun May 12, 2013 11:05 pm
Focus mk1 TDDI gross weight is around 1755kg (Base weight depending on aptional extras)
There has been a few members on here that have fitted focus gearboxes to their connects :wink:
2009 Jaguar X-Type 2.0D
IDS & GM GDS2 services
paul2012
Postby keirv6 » Fri May 17, 2013 1:27 pm
What's the differance in spedo drive locations do the gearboxes have codes to know what diff is fitted
keirv6
Postby ATL-driver » Fri May 17, 2013 4:56 pm
i had my connect 75 (11 plate) on the weigh bridge... 1680KG empty..... :S no wonder my 136BHP (remapped) 04 plate focus is so much faster....
ATL-driver
Postby blue estate » Fri May 17, 2013 6:07 pm
ATL-driver wrote:i had my connect 75 (11 plate) on the weigh bridge... 1680KG empty..... :S no wonder my 136BHP (remapped) 04 plate focus is so much faster....
:? You have a 75ps connect so your focus will be faster :roll:
blue estate
Postby g-man » Fri May 17, 2013 6:34 pm
heaviest 75 is 1507kg and heaviest of the lot is 1573kg........so u had something in it beside a full tank
g-man
Postby keirv6 » Sun May 19, 2013 6:54 pm
So I want to buy a gearbox this week to do this mod what box do I need cheers
keirv6
Postby paul2012 » Sun May 19, 2013 9:02 pm
keirv6 wrote:So I want to buy a gearbox this week to do this mod what box do I need cheers
What year is you connect ?
paul2012
Postby keirv6 » Sun May 19, 2013 9:19 pm
2004 90bhp
keirv6
Postby paul2012 » Sun May 19, 2013 9:26 pm
2004 90bhp
A MTX75 gearbox from a Focus mk1 will be fine (not a Focus 2005 onwards)
remember to remove the gear selector mech from the top of your original connect gearbox & fit it to the Focus one, otherwise you will find your gears are upside down)
paul2012
Postby keirv6 » Sun May 19, 2013 9:44 pm
keirv6
Postby keirv6 » Sun May 19, 2013 9:51 pm
Will the gearbox have a code to tell me what diff is inside or are they all 3.41
keirv6
Postby paul2012 » Sun May 19, 2013 9:55 pm
keirv6 wrote:Will the gearbox have a code to tell me what diff is inside or are they all 3.41
For Focus mk1 TDDI & TDCI they are both 3.41 :wink:
paul2012
Postby Keithm » Tue May 21, 2013 8:11 am
I have had a focus box fitted to my van when I first bought it. Mine is a 110 and I noticed that it isn't as sharp out of the blocks but is a lot better at motorway speeds as the gears seen longer, it will sit comfortably at 80mph at just over 2500rpm, which is what it used to do at 70mph. My mpg figures improved too.
Keithm
Postby Bailey. » Tue Jun 11, 2013 9:24 pm
I have only just spotted this reply, other than motorway driving once it was going was it a better power band than the original box? Does it feel little laggy in comparison? Cheers
Bailey.
Postby deps-online » Thu Jun 13, 2013 3:42 pm
Unless they weigh'd the van with him in it which could explain the difference
2005 T200L Connect 1.8 TDDI 75ps SWB with 45K on the clock
EGR Blank
Focus Air Box Mod (in the post)
JVC KD-R711
Edge ED205 3 Way Door Speakers
deps-online
