Grenadekid wrote: I dont want to speak outta turn in case your engine is different blueconnection but coolant bottle, engine mount (for handiness) and cambelt cover is all that needs removing iirc to access belt for change and i would change it anywhere from 80 to 100,000 just to be on the safe side as they are handy done 1/2 hr to 2 hours depending on your mechanical skills and only fit a genuine dealer or gates belt kit
Grenadekid wrote:Never used them m8 but i am a mechanic by trade, just marked the wheels iirc, but if you are doing one first time and arent sure best to use pins and lock it all off. they are prob the easiest belt you can get to change
local nick wrote:aye up, just had belt done on me van, gates kit ie belt and tensioner £48 like you say one of the easiest belts to do.
