NEW Project 2 2004 Connect T200 LX (Pic Heavy)
Re: NEW Project 2 2004 Connect T200 LX (Pic Heavy)
Postby paul2012 » Fri Sep 27, 2013 12:03 am
Sorted handbrake problem
2009 onwards lever with the original 2004 forward section of hanbrake cable.
As you can see the 10mm adjustment nut is wound all the way down & can't go any further.
Removed lever & old cable, - No need to go underneath. Once rubber grommet is removed, it gives you clear access to release cable from rest of assembly :D
Here you can see the difference in lengths between the 2003-2009 (top) & 2009 onwards cables.
Handbrake lever & new cable fitted - now adjusted & working perfectly :wink:
2009 Jaguar X-Type 2.0D
IDS & GM GDS2 services
paul2012
Postby paul2012 » Sun Sep 29, 2013 2:20 am
Oh well, trouble getting hold of new rear brake pipes (ABS) Ford can only get NON ABS ones :(
So a trip to local breaker picked up a pair from a 2006 connect for a £5
Unfortunately I can only use the O/S rear pipe, that is fairly clean - mostly covered up by fuel tank & spare wheel. so that went straight on.
N/S one is no good (MOT failure - excessively corroded)
I ordered a non ABS N/S rear hosefrom Ford, which runs from unions just in front of fuel tank to LSV - I was Surprised to get a pair for £12 :D
Placed along side the ABS pipe to see if I can use it. Sure enough the forward part is the same.
Cut sown to size & slight alteration, fit new end then installed it - job done :D
I now require the Last forward section of brake pipe from ASB pump to first union above steering rack for rear middle section. Unfortunately Ford don't supply.
paul2012
Postby Altransit » Sun Sep 29, 2013 10:56 am
Why not just get a copper pipe made up at a motor factor :?: :?
Postby paul2012 » Sun Sep 29, 2013 3:12 pm
Altransit wrote:Why not just get a copper pipe made up at a motor factor :?: :?
They require the old one to make up a new one too. Unfortunately I don't have the old pipe from ABS pump from a 2009 onwards connect :(
paul2012
Postby paul2012 » Mon Sep 30, 2013 3:33 am
Fitted 2 brackets for ABS wheel sensor wiring to O/S front & lower cover for Aux drive belt.
Also removed wing to mount the ECU
Refitted wing, Arch trim & wheel well liner.
paul2012
Postby paul2012 » Mon Sep 30, 2013 8:50 pm
New drivers seat belt clasp/buckle arrived today :D
Connects to airbag module & turns off seatbelt warning light (also the chime) on instrument cluster when you put your seat belt on.
Fitted to connects from 2009 onwards :wink:
paul2012
Postby paul2012 » Wed Oct 02, 2013 6:21 pm
Fitted new side trims today. These are from Ford & are handed (RH/LH)
I'm going to colour code all door handles :D
New cover for jack etc. when I do get round to plyboard the rear, I will cut a window then Jack etc can be stowed away properly :wink:
Finally New N/S driveshaft has arrived, now I can get on with fitting N/S front ABS hub at the same time.
paul2012
Postby paul2012 » Sat Oct 05, 2013 10:32 pm
Today fitted new N/S drive shaft & ABS hub, Waiting for last front ABS sensor wiring bracket to arrive
Also small brackets for rear ABS sensor wiring have been fitted on both sides
paul2012
Postby Lennie » Mon Oct 07, 2013 9:25 pm
liking this , your a clever fooker...
Lennie
Postby paul2012 » Tue Oct 08, 2013 1:14 am
Lennie wrote:liking this , your a clever fooker...
:oops: :D Thanks more updates to follow :wink:
paul2012
Postby paul2012 » Tue Oct 08, 2013 1:52 am
Update on progress of patching in the 2009 onwards equipment onto the 2007 dash loom
Currently still working on it, here's the start.
Started at the instrument cluster plugs, first thing was the label every single wire on both of the 2007 instrument cluster plugs. (Full wiring diagrams are very handy for this job :mrgreen: )
Then did the same to the 2009 onwards cluster plugs.
Instead of cutting & joining wires, I removed the pins from the 2007 plugs & refitted in the correct locations to the 2009 onwards plugs :mrgreen:
This what it looks like when that part is done. Not all wiring at the 2007 plugs is fitted to the 2009 onwards ones.
Wiring not used by the 2009 onwards instrument cluster have to be chased back through the loom. All the way back to Fuse panel & plugs that connects to engine bay loom through bulkhead.
As they are connected to GEM module instead :!: .
There's extra wiring required for 2009 onwards cluster to column controls for example menu buttons etc & also low/dipped beam interrupt relay has to be added.
Now the Boring Tech Info bit :lol: :lol: 8)
This will apply to dash wiring looms on connects from 2006-2009 :wink:
Following wiring already present on 2007 cluster plugs & now fitted to 2009 onwards instrument cluster plugs at the correct pin locations
VBAT J2-1
V IGN J2-6
V ACCESSORY J1-14
GND J2-2
HANDBRAKE / BRAKE FLUID LEVEL J2-7
ILLUMINATION J1-24
BRAKE PEDAL SWITCH J2-19
ACCELERATOR PEDAL 5V+ J2-12
ACCELERATOR PEDAL INPUT J2-18
ACCELERATOR PEDAL GND J2-13
CLUTCH SWITCH J2-20
FUEL GAUGE SIGNAL J2-14
FUEL GAUGE RETURN J2-15
PATS RX/RX J2-26
PATS TX/TX J2-25
HS-CAN HIGH J2-23
HS-CAN LOW J2-24
MS-CAN HIGN J2-21
MS-CAN LOW J2-22
The following wiring not present on 2007 dash loom & is required to be patched in for 2009 onwards instrument cluster & column switchgear
AMBIENT AIR TEMP (OUTSIDE TEMP) IN J2-17
AMBIENT AIR TEMP (OUTSIDE TEMP) OUT J2-16
HIGH BEAM RELAY J1-7 NEGATIVELY OPERATED (2007 RELAY IS POSITIVELY OPERATED - MOD REQUIRED)
LOW/DIPPED BEAM INTERUPT RELAY J1-8 (NOT PRESENT ON 2003-2009 CONNECTS)
MENU DOWN J1-20 CONNECTS TO INDICATOR STALK/COLUMN SWITCHGEAR
MENU UP J1-19 CONNECTS TO INDICATOR STALK/COLUMN SWITCHGEAR
MENU RESET J1-21 CONNECTS TO INDICATOR STALK/COLUMN SWITCHGEAR
HIGH BEAM FLASH/PASS J1-2 CONNECTS TO INDICATOR STALK/COLUMN SWITCHGEAR
HIGH BEAM J1-2 CONNECTS TO INDICATOR STALK/COLUMN SWITCHGEAR
AIR RECIRC J1-18 CONNECTS TO AIR RECIRCULATION SWITCH
Wiring on the 2007 instrument cluster plugs NOT used on 2009 onwards clusters & are connected to GEM module instead
HEATED FRONT SCREEN RELAY & SWITCH
HEATED REAR SCREEN/MIRROS RELAY & SWITCH
INTERIOR LIGHT RELAY
BATTERY SAVER RELAY
INTERMITTENT FRONT WIPER RELAY & STALK/COLUMN SWITCHGEAR
REAR WIPER RELAY & STALK/COLUMN SWITCHGEAR
FRONT/REAR WASHERS & STALK/COLUMN SWITCHGEAR
LH/RH INDICATORS & STALK/COLUMN SWITCHGEAR
Wiring no longer required
AIR BAG (warning light)
ABS (warning light)
HIGH BEAM (warning light)
paul2012
Postby paul2012 » Sat Oct 12, 2013 10:56 pm
Decided to fit a new rear heat shield as original one was missing :?
To finish the rear, colour code rear door handle & bumper. :D
paul2012
Postby tez » Sun Oct 13, 2013 1:40 am
that's what is missing off my back axle ?
tez
Postby Trender » Sun Oct 13, 2013 8:31 am
tez wrote:that's what is missing off my back axle ?
Heat shield or stabilizer ? Tez
If its the stabilizer I've just checked my 2013 and mines missing as well... is that ok or should it be there ?
....Trender.... 2018 Limited
Trender
Postby tez » Sun Oct 13, 2013 12:30 pm
the stabilizer m8
tez
