NEW Project 2 2004 Connect T200 LX (Pic Heavy)
Re: NEW Project 2 2004 Connect T200 LX (Pic Heavy)
Postby paul2012 » Fri May 31, 2013 9:14 pm
Decided to fit the crome bonnet trim today :D
2009 Jaguar X-Type 2.0D
IDS & GM GDS2 services
paul2012
Postby tipp3r » Sat Jun 01, 2013 8:03 pm
I've cut the plugs of 2010 loom for clocks the couler of the wires don't match old loom
tipp3r
Postby paul2012 » Sun Jun 02, 2013 7:49 pm
tipp3r wrote:I've cut the plugs of 2010 loom for clocks the couler of the wires don't match old loom
No not all the wire colours on your original dash loom will match to the ones on the 2010 loom. This is due to wiring differences for interior lights, wipers etc.
your original instrument cluster has CTM (Timer) built into it which controlled the interior lights & intermittent wipers, heated screen & mirrors * if fitted.
Hence why they dont't work when instrument cluster is unplugged.
The 2010 instrument cluster has no CTM therefore it does not control the above systems. They are controlled by the GEM module which has CTM built into it.
If you wish to use the 2010 instrument cluster, the GEM module has too be installed as well. You will need to make up a new loom & patch it into your existing dash loom.
so that the following are operated via the GEM module
Central Locking
Intermittent wipers
Interior lights (doors)
Indicators & hazards
Headlamps
Side/parking lights
Battery saver (interior dome lights)
AIr recirculation
Heated Front screen (if fitted)
Heated wing mirrors (if fitted)
Rear Wipers (if fitted)
Auto headlamps & wipers (if fitted)
It is complex & unfortunately not simply plug & play :(
paul2012
Postby paul2012 » Mon Jun 03, 2013 6:25 pm
To fit ABS with ESP to my connect. I am using the ABS wiring loom from a 2005 connect.
In order to salvage the wiring for the ASB Pump etc.
I started with this, part engine bay loom, front ABS sensor wiring & pump wiring with fuse/ relay panel
Stripped it down, now I have the full ABS wiring loom.
Already have fitted the section that runs from front bulkhead to rear N/S light & sensor loom from N/S light to rear ABS sensors
I just need to fit the ASB pump & sensor loom having retained the original terminals on 12V+ feeds from fuse/relay box for ABS pump. This is very simple to fit as it is :wink:
But as I am fitting ABS with ESP, I need to add a few more pins to the ABS pump plug for Yaw sensor etc.
paul2012
Postby PeterBuzzacott » Tue Jun 04, 2013 3:51 pm
Nice work mate and thanks for posting in such detail. Your van has come up a treat.
PeterBuzzacott
Postby paul2012 » Tue Jun 04, 2013 9:18 pm
When fitting the 2010 forward section of centre floor console.
You will require this mounting bracket, which is the base for the gearshift assembly
Available from Ford at £10 (Trade)
Ford Part No F5050131
This is what the forwards section of centre floor console is mounted to :wink:
The rear section of centre floor console is mounted using this bracket (fitted to floor behind Handbrake lever assembly)
paul2012
Postby paul2012 » Sat Jun 08, 2013 6:24 pm
As my connect originally had front fog lights, the headlight switch that came with the 2010 dash was not equipped for them.
So I obtained replacement from a C-Max, which works perfectly :D
After receiving a few PM's on "how to stop the front bumper sagging in the middle & distorting bottom of top grille ?"
I advise to replace the lower bumper reinforcement bar (The thin bar that is mounted to the bottom of slam panel between headlights shown in pic below)
Part required Ford Part no F4992893 - This is the part where top of bumper clips onto just below the grille :!:
When fitted, bumper & bottom of top grille should look like this :wink:
paul2012
Postby millertime_1985 » Sat Jun 08, 2013 10:33 pm
paul2012 wrote:As my connect originally had front fog lights, the headlight switch that came with the 2010 dash was not equipped for them.
That's one hell of a facelift you have done there... almost as impressive as the guy that facelifted a mk3/4 to look like a mk 6/7 (I forget which ones , off the top of my head)
Its Not a Van..... Its a Transit
millertime_1985
Postby millertime_1985 » Sun Jun 09, 2013 11:55 am
looking over more of this thread I have to wonder, just how handy do you have to be to be able to do this sort of thing...
not that I have any grand designs like this for my own TC... but I can't imagine its physically/practically easy doing such a drastic facelift to your TC
especially since I doubt they sell an instruction manual. :lol:
millertime_1985
Postby paul2012 » Sun Jun 09, 2013 7:28 pm
millertime_1985 wrote:looking over more of this thread I have to wonder, just how handy do you have to be to be able to do this sort of thing...
On changing the front bumper it's straight forward to fit. Simply bolts into place.
Which can be easily done by anyone with the right info
Fitting the main dash is also straight forward, except for the floor centre console.
Although the main body shell looks the same on all models from 2003 to present, I have found there are differences in mounting points & brackets etc.
As for wiring the later instrument cluster & all modules etc, newer vehicles are getting far more complex with onboard diagnotic & computer systems.
theoretically experience / knowledge in vehicle electrical systems is preferred especially when fitting them to vehicle that were not originally equipped with them.
I wouldn't even bother getting a Haynes manual, they only supply a service manual that mostly covers connects from 2006-2009 with partial information on 2009 onwards.
The electrical system it covers are only 2006-2009 even then it's incomplete :shock:
In the process of adding these systems/modules to my connect.
I cross referenced 2003-2006 wiring diagrams with 2009 onwards ones obtained from Ford & worked it out from there.
& ended up putting together a 30 page electrical manual detailing on wiring the 2009 systems/modules etc into a 2003-2006 connect.
Which lists all wiring diagrams, connection points, diagrams of connection plugs & pin arrangements etc.
Then used it as my instruction manual on installation, otherwise it would have been a nightmare to remember everything. :wink:
paul2012
Postby paul2012 » Thu Jun 13, 2013 8:28 pm
PeterBuzzacott wrote:Nice work mate and thanks for posting in such detail. Your van has come up a treat.
Thanks :D
Still have several more things to do yet 8)
paul2012
Postby paul2012 » Fri Jun 14, 2013 7:20 pm
Bagged this for a fiver - chap didn't know what it was :?
Removed from a 2012 connect, I was supprised to see it was virtually stripped. it had only been in for a couple of days
Yaw rate sensor complete with mounting bracket - The final part for the ESP & hill start assist :D
These cost over £400 new from Ford :shock:
Although still waiting for the ABS pump to arrive :evil:
paul2012
Postby millertime_1985 » Fri Jun 14, 2013 7:38 pm
paul2012 wrote:Bagged this for a fiver - chap didn't know what it was :?
by the end of your project, how much of your van will remain the same as when it was shipped out of turkey...
and.. how much do you reckon you will have Saved, over just buying an "09" model TC?
millertime_1985
Postby paul2012 » Fri Jun 14, 2013 7:54 pm
Not alot is original for a 9 year old connect apart from the shell everthing else has been replaced at some point.
With the cost of van & parts for conversion, estimated cost to date is around £2000
Alot cheaper than a good used low mileage 2009 onwards basic model :mrgreen:
paul2012
Postby g-man » Fri Jun 14, 2013 8:00 pm
and worth a lot less :wink:
g-man
