What did you do to your connect today?
Re: What did you do to your connect today?
Postby Drizz » Tue Jun 26, 2012 6:43 pm
Removed my half solid, half mesh bulkhead and started making a wooden one
Marked where it'll be cut and turned 90 deg
And now the seats can go back more:
Drizz
Postby Drizz » Tue Jun 26, 2012 6:44 pm
Obviously it'll be carpeted too....
Drizz
Postby paul2012 » Tue Jun 26, 2012 8:55 pm
Finally,
I have got my electric windows & mirors all wired up properly & mk2 dash fitted so it matches colour with the door cards !
Bought some new connector pins for the door loom sockets (located in A pillars - door looms simply just plug into) from Ford.
Added the extra wiring linking both doors together. 12v+ wiring for elect windows & mirrors was already connected to Fuse panel, but was not connected to anything else !
12v+ wiring from :-
Fuse 47 stopped at connector C53
Fuse 50 stopped at S155
Fuse 55 stopped at S156
Very Handy if you have the Ford TIS manual & a Proper Multimeter ! :D
Added the correct fuses in there proper arrangement
Fuse 55 25A for elec windows
Fuse 47 5A for elec mirrors
Fuse 50 7.5A for heated mirrors
2009 Jaguar X-Type 2.0D
IDS & GM GDS2 services
paul2012
Postby paul2012 » Tue Jun 26, 2012 8:58 pm
This wiring info is usefull for people who wish to fit the connect mk2 elec windows & Heated elec mirrors into the mk1 connect
The Pins in the door loom sockets are clearly numbered from 1 to 20, the sockets are located in the A Pillars (door looms just simply plugs into them)
Please Note this the wiring details for fitting the elec windows & heated elec mirrors removed from connect 2006 onwards (NO SEPERATE RELAY IN DRIVERS DOOR) into a mk1
DRIVERS DOOR SOCKET - PIN CONNECTIONS
PIN 9 12V+ FOR ELEC WINDOWS
PIN 12 12V+ FOR ELEC MIRRORS
PIN 20 12V+ FOR HEATED MIRRORS
PIN 11 LINK TO PIN 11 ON PASSENGER DOOR SOCKET - FOR ELEC WINDOW
PIN 5 LINK TO PIN 5 ON PASSENGER DOOR SOCKET - FOR ELEC WINDOW
PIN 13 LINK TO PIN 13 ON PASSEENGER DOOR SOCKET - FOR ELEC MIRROR
PIN 15 LINK TO PIN 15 ON PASSENGER DOOR SOCKET - FOR ELEC MIRROR
PIN 16 LINK TO PIN 16 ON PASSENGER DOOR SOCKET - FOR ELEC MIRROR
PASSENGER DOOR SOCKET - PIN CONNECTIONS
PIN 11 LINK TO PIN 11 ON DRIVERS DOOR SOCKET - FOR ELEC WINDOW
PIN 5 LINK TO PIN 5 ON DRIVERS DOOR SOCKET - FOR ELEC WINDOW
PIN 13 LINK TO PIN 13 ON DRIVERS DOOR SOCKET - FOR ELEC MIRROR
PIN 15 LINK TO PIN 15 ON DRIVERS DOOR SOCKET - FOR ELEC MIRROR
PIN 16 LINK TO PIN 16 ON DRIVERS DOOR SOCKET - FOR ELEC MIRROR
Fuse 55 25A for elect windows - CONNECT TO PIN 9 ON DRIVERS & PASSENGER DOOR SOCKETS
Fuse 47 5A for elect mirrors - CONNECT TO PIN 12 ON DRIVERS DOOR SOCKET ONLY
Fuse 50 7.5A for heated mirrors - CONNECT TO PIN 20 ON DRIVERS & PASSENGER DOOR SOCKETS
paul2012
Postby van mann » Tue Jun 26, 2012 10:45 pm
Excellent wiring write up as i,m have the same problem,no ignition live to doors.How much were the pins from ford and do they come with a lengh of wire or do you crimp your own to the pins?
van mann
Postby dieselboy1978 » Wed Jun 27, 2012 9:59 pm
Finally got my wheel centres through for my new alloys and then I pimped them with these.
Probably not everyones taste but here is final result.
Also have re carpeted the van in the drivers and passengers side ready for fitting of some nice leather Recaro seats I managed to get hold off.
Bank account emptied by
DELPHI
dieselboy1978
Postby paul2012 » Thu Jun 28, 2012 9:53 pm
Today fitted my new stereo unit & everything works as it should.
Althought I did not need to enter the Keycode as the unit is in "UNCONFIGURED MODE" ?
I just need to get hold of a bluetooth module & mic
I should be able to find these on a late Focus or Mondeo !
paul2012
Postby Drizz » Thu Jun 28, 2012 10:00 pm
Overloaded it lol
Drizz
Postby valetech » Sat Jun 30, 2012 5:05 pm
fitted a free sticker to my sunstrip today.
molested by:
19s is how we roll
valetech
Postby Hotwheels » Sat Jun 30, 2012 9:13 pm
NikFrisbee wrote:Image
Got this to fit when i get time and new arches all round.
Will the facelift bumper fit onto a T200 2002 model van SWB version cheers.
Hotwheels
Postby Connect-rick » Sun Jul 01, 2012 10:03 am
Also will be fitting this as well
together with this - my new stereo !
Image[/quote]
Hi Paul, where did you get these parts from? I like the idea of it being silver as it breaks the dash up a bit. Just been wondering whether it'd look good in mine sprayed white!
Did the stereo come like that? I've had a quick look on fleabay and can only find ones that look like they fit behind the dash
2006 white 75ps
EGR blank
Sony head unit, vibe slick 6x9 and ripspeed rs132 in front.
Connect-rick
Postby g-man » Sun Jul 01, 2012 11:26 am
yes.......with later front arch's and splitter
g-man
Postby dieselboy1978 » Sun Jul 01, 2012 8:50 pm
Washed my van and fitted new style rear lights and got some new front headlights to fit.
DELPHI
dieselboy1978
Postby Hotwheels » Sun Jul 01, 2012 11:41 pm
Hi were would I get them from and how much would it cost any idea also if you change the front arches would the back have to be done as well also is it an easy job changing theise cheers.
Hotwheels
Postby g-man » Mon Jul 02, 2012 9:53 am
easy enough to change bumper & f/arch's,you probably will need some xtra plastic arch clips as they can break,ebay or scrappies or on here,try to get oem ones as pattern ones can be a bad fit......rear arch's don't need doing
g-man
