What did you do to your connect today?
Re: What did you do to your connect today?
Postby Mylee » Wed Jul 18, 2012 10:04 pm
Mod your Transit wrote:or you could stick it on the back door.
You should know, I've the "shocker" and a heli on the back!
Mylee
Postby paul2012 » Thu Jul 19, 2012 3:15 am
WHAT A BARGAIN !
Just purchased a complete rear axle with disc brakes - removed from a 2011 Connect for a cool £150 from ebay :D 8) 8)
Everything is there including brake hoses, the only thing missing is the handbrake cable.
2009 Jaguar X-Type 2.0D
IDS & GM GDS2 services
paul2012
Postby Drizz » Thu Jul 19, 2012 6:53 pm
Nice one on the beam!
So today i started taking my dash apart:
Cut out a template from cardboard:
And checking clearance:
Drew the heater controls and DIN apature:
Transfered it over to some thin wood as its easier to use for templates than cardboard:
And roughly cut out for trialing:
So ill carry on making it up then ill make it for real!
Drizz
Postby mike-dyson » Thu Jul 19, 2012 8:23 pm
Added passengers seat Mk3 Mondeo St220 Recaro and made a nice sticker for the plate seat bolted too.
what is it you have done here? is it a steal plate with the seat welded to it and and bolted into the van?
I'm looking at getting some better seats for mine and i think this could be the solution to fitting some.
mike-dyson
Postby dieselboy1978 » Thu Jul 19, 2012 9:32 pm
Drizz wrote:Nice one on the beam!
So are you scrapping the heat blowers in the middle at the top then?
Bank account emptied by
DELPHI
dieselboy1978
Postby dieselboy1978 » Thu Jul 19, 2012 9:36 pm
mike-dyson wrote:Added passengers seat Mk3 Mondeo St220 Recaro and made a nice sticker for the plate seat bolted too.
No welding mate.
Taken standard seats out, Got some metal plate, about 1/4 inch thick, and picked up the existing bolt holes in chassis.
Then worked out where the seat sits best on the plates and drilled and tapped thread into plate.
Bolted seat onto plate. If need to put original seats back in then plates just come out and seats bolts back onto floor plan.
Used 12.9 or 14.9 high tensile bolts for bolting plates and seats in. No worries about bolts snapping or ripping from threads.
Then I just powder coated the plates to make the finish much better and put a green sticker saying CONNECT to finish it off.
DELPHI
dieselboy1978
Postby Drizz » Thu Jul 19, 2012 9:51 pm
dieselboy1978 wrote:So are you scrapping the heat blowers in the middle at the top then?
Yeah, thats the plan. Never use them anyway
Drizz
Postby dieselboy1978 » Thu Jul 19, 2012 9:59 pm
Will be very interesting to see how this turns out mate
DELPHI
dieselboy1978
Postby Drizz » Thu Jul 19, 2012 10:04 pm
Im not the most creative. Mechanically fine, but not creative lol
Drizz
Postby Connect-rick » Thu Jul 19, 2012 10:07 pm
Is the iPad going to be a permanent fixture?
2006 white 75ps
EGR blank
Sony head unit, vibe slick 6x9 and ripspeed rs132 in front.
Connect-rick
Postby Drizz » Thu Jul 19, 2012 10:12 pm
No, removable
Drizz
Postby C8XY » Thu Jul 19, 2012 10:21 pm
Drizz wrote:No, removable
What sort of finish are you hoping to achieve with the surround?
Are you going for sprayed mdf or material covered etc? I'd imagine its going to be a bit of a headache coming up with a mounting solution that works well which enables you to remove the iPad?
I'm looking forward to seeing it finished :)
Also, if its 3G - apple are releasing turn by turn navigation with iOS6 so will be awesome to see that in the dash!
C8XY
Postby Drizz » Thu Jul 19, 2012 10:24 pm
I use it for nav at the moment on a separate mount. Plan is to be able to drop it in from the top. ill have it skimmed and painted piano black with a flocked dash or Ill flock it once its done with the rest of the dash
Drizz
Postby Honey monster » Thu Jul 19, 2012 10:28 pm
Honey monster
Postby C8XY » Thu Jul 19, 2012 10:29 pm
Drizz wrote:I use it for nav at the moment on a separate mount. Plan is to be able to drop it in from the top. ill have it skimmed and painted piano black with a flocked dash or Ill flock it once its done with the rest of the dash
Good old flock!! :D
Make sure you take pics along the way mate, pretty cool mod
C8XY
