ray0098 wrote:if i turn it over all these come up
1563
1664
0409
1563
1664
1608
0335
0216
2139
2141
but all these go off but p 1300 wont go off it stays on
paul2012 wrote:ray0098 wrote:if i turn it over all these come up
1563
1664
0409
1563
1664
1608
0335
0216
2139
2141
P1563 Injection Pump Control Module Requesting Engine Stop
P1664 Injection Pump Control Module Malfunction
2 above are common for a failed fuel pump on TDDI's
P0409 Exhaust Gas Recirculation Sensor "A" Circuit
P2141 Exhaust Gas Recirculation Throttle Control Circuit "A" Low
P0216 Injector/Injection Timing Control Circuit
P0335 Crankshaft Position Sensor "A" Circuit
P1608 Watchdog Malfunction
P2139 Throttle/Pedal Position Sensor/Switch "D" / "F" Voltage Correlation
VanBooter wrote:I know this is an old topic but it might help someone, I have the P1300 code up on the bus no other codes and it will not delete. There are no symptoms she is running great and just done a 1500 mile trip. Looks like Ford don't even know what that code is other than the excuse to hand you over a large bill for work which may/may not be needed.
VanBooter wrote:
I have no other codes up and this was just a random check to see if there were any old codes which need deleting as this vehicle is new to me.
I have read different opinions, one Ford dealer say it's a redundant code and another say the pumps knackered. I think the best opinion was the turbo connector or it's wiring, but as I say I have no symptoms so leaving well alone - damn these electronics
paul2012 wrote:
P1300 Boost Calibration Fault
Has nothing to do with fuel pump
What year is your Connect
Yea I know what it's supposed to be in the book, just relaying what I've read about it
Mine is same as profile pic only it's a 2002 350 2.4 RWD
By the way if you search these forums it's a rare code only a couple of topics
