engine making noise at higher revs
Postby mccririck » Fri Mar 09, 2012 9:21 pm
My Transit Connect has started making a moaning noise above 2000 revs. I started noticing it yesterday. It is 4 years old and has done about 51k miles. I thought it might be the turbo but it is a moan rather than a whine. Reminds me a bit of the noise buses make. Any ideas what could be wrong?
mccririck
Re: engine making noise at higher revs
Postby get connected » Fri Mar 09, 2012 9:30 pm
Hi and Welcome....
Someone will be along soon, can you describe the noise a little better, driving conditions, does it do it at idle?
Mine has a little whistle at about 2250rpm on accelerate and decelerate, ever since I changed the exhaust system!
DC
Keep a smile on your face at all times! The others think you know something that they don't !!!
get connected
Postby mccririck » Fri Mar 09, 2012 9:32 pm
No it only becomes noticeable above 2000 revs. It does it in any gear and out of gear.
mccririck
Postby Kent Discos » Sat Mar 10, 2012 12:52 am
mccririck wrote:No it only becomes noticeable above 2000 revs. It does it in any gear and out of gear.
Can you explain further?..what happens if you clutch down?
How would you explain the moan... And where about from the bay does it sound like its coming from... If you can make it make the noise whilst stationary have a friend identify the area it's coming from
Jack Wilson | 2017 Transit Custom 290 130PS from Absolute Vans
Kent Discos - http://www.kentdiscos.me.uk
Kent Discos
Postby Jammin » Sat Mar 10, 2012 7:46 pm
Hi just found this forum looking for advise with the exact same problem. So hi! At 2000revs in any gear I get a noise like the old school bus, sounds like it's coming from passenger side, but after 2200rev sound goes, if it is out of gear I dont get any noise rev fine. Could it be a gear box issue? Mine has done 97k and the gear box is a bit of a soup bowl, 1st, 3rd and 5th are anyone's quess to find at times. :lol: Any ideas?
Jammin
Postby mccririck » Sat Mar 10, 2012 10:10 pm
Well that's not the exact same problem because mine just gets worse with more revs and I get it out of gear too.
mccririck
Postby joeyboy » Sun Mar 11, 2012 4:30 pm
mccririck wrote:Well that's not the exact same problem because mine just gets worse with more revs and I get it out of gear too.
I think I have this problem I tried filming it on the phone but wont do it, Its like a whine that sounds like stero feed back??? thats only way i know how to explain except its louder and stero is off!
joeyboy
Postby mccririck » Thu Mar 15, 2012 11:21 pm
I'm wondering if it may be a crack in the manifold or a dodgy exhaust.
mccririck
Postby mccririck » Fri Mar 30, 2012 9:52 pm
It was the alternator.
mccririck
Postby Kent Discos » Fri Mar 30, 2012 10:51 pm
mccririck wrote:It was the alternator.
Always the last thing you'd think of but makes sense!
Kent Discos
Postby Michaelnot » Wed Jun 06, 2018 3:56 pm
Jammin wrote:Hi just found this forum looking for advise with the exact same problem. So hi! At 2000revs in any gear I get a noise like the old school bus, sounds like it's coming from passenger side, but after 2200rev sound goes, if it is out of gear I dont get any noise rev fine. Could it be a gear box issue? Mine has done 97k and the gear box is a bit of a soup bowl, 1st, 3rd and 5th are anyone's quess to find at times. :lol: Any ideas?
Think I have the same issue, did you event find a solution?
Michaelnot
