valetech new project
Postby valetech » Wed Jun 06, 2012 11:00 pm
picked up the new project the other day.got it as a non-runner,once i got it unloaded off my trailer i set to work.
first job was to try to get it running,which i did to find its dropped a valve :(
have now started to remove the head
did'nt like the interior seats so changed them to theseImage
once running i think it needs lowering and some rear disc brakes :wink:
maybe a sportvan bodykit and a colour change
molested by:
19s is how we roll
valetech
Re: valetech new project
Postby g-man » Wed Jun 06, 2012 11:11 pm
8) rs going in?
g-man
Postby dieselboy1978 » Wed Jun 06, 2012 11:27 pm
Did the seats fit in easy?
How much tinkering did you have to do?
Bank account emptied by
DELPHI
dieselboy1978
Postby valetech » Wed Jun 06, 2012 11:28 pm
no mate.was going to do ST24 2.5 v6 but i like the factory fitted lpg system thats in the van.
so i may just play with the 16v thats already in it
fast road cams
decat 4 branch manifold
etc etc
molested by:
19s is how we roll
valetech
Postby valetech » Wed Jun 06, 2012 11:29 pm
dieselboy1978 wrote:Did the seats fit in easy?
no was a right bitch.drivers seat is electric :D .
molested by:
19s is how we roll
valetech
Postby g-man » Wed Jun 06, 2012 11:31 pm
and stick a 2.3 ported and gas flowed head on it :wink:
g-man
Postby valetech » Wed Jun 06, 2012 11:33 pm
not 100% sure what i can get away with coz of the lpg
molested by:
19s is how we roll
valetech
Postby dieselboy1978 » Wed Jun 06, 2012 11:36 pm
Think you will have more fun with an lpg than a diesel and good to be different.
If you get stuck with lpg i can ask the guy who has whole fleet of them in Connects and Transits.
Seats look sweet.
Not seen any with Cosworth seats in.
DELPHI
dieselboy1978
Postby valetech » Wed Jun 06, 2012 11:45 pm
thank mate i may need it,i know jack s**t about lpg.tank is where the spare wheel normally goes.so once again no spare for me. :roll:
i have seen some where a connect with seirra cossy seats.
molested by:
19s is how we roll
valetech
Postby dieselboy1978 » Wed Jun 06, 2012 11:50 pm
Does the van have a fitted Bulkhead?
You could sit the bulkhead back and put maybe a spacesaver behind passngers seat?
Just an idea.
Did you want me to see if i have those nets behind my ply lining on rear doors?
If i do and you want it you can have it F.O.C
DELPHI
dieselboy1978
Postby valetech » Thu Jun 07, 2012 7:33 pm
well the head is off,have taken it to a engine shop i use to have it checked and to have all 16 valves reseated if needed
engine looks to me like its been rebuilt at some point in the past.
was a bit shocked at the cost of a new head gasket kit £108 which doesnt come with new head bolts :roll:
molested by:
19s is how we roll
valetech
Postby dieselboy1978 » Thu Jun 07, 2012 9:17 pm
Seems a hell of alot of money for headgasket.
Where is that from?
DELPHI
dieselboy1978
Postby valetech » Mon Jun 11, 2012 3:04 pm
Got the phone call from my engine builders today.
8 New exhaust valves needed.
Piston 4 has a burnt out and cracked valve :shock:
molested by:
19s is how we roll
valetech
Postby dieselboy1978 » Mon Jun 11, 2012 4:08 pm
At least you found the problem as to what the misfire was
DELPHI
dieselboy1978
Postby martynx » Tue Jun 12, 2012 11:54 pm
Not 100% on this but isnt there an issue with these lpg ones running too hot which causes the premature valve probs ?
martynx
