Won't go into gear
Won't go into gear
Postby reedy22 » Tue Aug 14, 2012 8:30 am
Hi guys, I am new to the forum. I own a 54 plate transit connect, a couple months ago it got quite difficult to put into (any) gear, but then after a few days it free'd up and went back to normal, now.. It has gotten so you cant pull it into gear if the engine is on. I called green flag, as i have cover, i thought i may aswel use it just to get there oppinion. They said the clutch is gone. I'm not mechanic but to me i thought the clutch usually slips loads etc before it goes (like i said i am no expect so excuse me if i sound ignorant) my thought is that the clutch is not engaging properly i did a little research before posting on here and i saw that a good place to start is by changing the transmission fluid and filter, does anyone agree with this or have any other suggestions. Any help would be much appreciated. Thankyou. Tom
reedy22
Re: Won't go into gear
Postby white.akita » Tue Aug 14, 2012 8:37 pm
could be the selector on top of the gearbox if your van is front wheel drive.
white.akita
Postby munchiestubro » Tue Aug 21, 2012 2:44 pm
i have happen to me your need new clutch on van
munchiestubro
Postby gt_addict » Tue Aug 21, 2012 3:05 pm
Could well be the slave cylinder or something to do with the hydraulics as I they fail you can't engage or disengage the clutch to select a gear.
gt_addict
Postby retrofreek123 » Tue Aug 21, 2012 6:45 pm
Needs a new clutch mate same happend to me
Transit connect 58reg tdci
Focus air box
Egr blank
Ford Trims
Rubber mats
Aux lead
Private plate
Moon dust silver
retrofreek123
