Fitting Inverter
Fitting Inverter
Postby kjb » Sun Oct 07, 2012 1:16 pm
Has anyone fitted a inverter to a connect?with the onset of winter & needing a facility to recharge power tools/hand held torches ect I was exploring the cost of buying & fitting such an item,wondered where was the best place to pick up a feed as the inverter would be situated towards the n/s/r of the cargo area,Maplins seems as good as anywhere to purchase a inverter,unless anyone has any suggestions
kjb
Re: Fitting Inverter
Postby GKandR4CH » Sun Oct 07, 2012 1:26 pm
I've got an inverter.
Wired it direct to the amp live lead, which runs to the battery. I am using 13mm cable direct to the battery.
Useful for tools, kettle etc.
Read the forum rules
GKandR4CH
Postby whitemice » Sun Oct 07, 2012 1:34 pm
I've got the 300w maplins one in their discounted 20 quid deal.
It uses a fag lighter socket at 150w and direct battery connection at 300w so you need fused 20A 2.5mm sq for fag mode and for direct run from battery then fused wire something like this will do,
.co.uk
Or a single fused at battery 4mm sq positive to a clamp post or direct wired and use vehicle earth.
https://www.youtube.com/watch?v=jIaGWURONRU
'' VOTE Kim Jong Unwell.
Mike writ '' a vote for lABOUR is a vote for islam and a conservative vote is a vote for islam and a vote for liberal is a vote for islam. ''
DBVM ''a vote for UKIP is a vote for islam''
whitemice
Location: normalised heavily chemtrailed cretinous individual just like you
Postby kjb » Sun Oct 07, 2012 1:39 pm
Hardwired to battery is the way to go I think,where is the best place to enter the bulkhead with the wiring though?
kjb
Postby whitemice » Sun Oct 07, 2012 1:42 pm
kjb wrote:Hardwired to battery is the way to go I think,where is the best place to enter the bulkhead with the wiring though?
Often easier to run it underneath vehicle, should be easy to find an internal routing though, make sure it's fused as close to battery as possible, i like marine grade waterproof blade holders for this sort of stuff @£2.50 at chandlers pick up an 8mm ring crimp too.
whitemice
Postby dieselboy1978 » Sun Oct 07, 2012 4:06 pm
I have a 600w power inverted mounted on bulk head. Also have a split charger and battery running in back and it is all wired and secure underneath the vehicle. Very secure as easiest way to get wired up.
Bank account emptied by
DELPHI
dieselboy1978
Postby kjb » Sun Oct 07, 2012 7:55 pm
dieselboy1978 wrote:I have a 600w power inverted mounted on bulk head. Also have a split charger and battery running in back and it is all wired and secure underneath the vehicle. Very secure as easiest way to get wired up.
You have talked yourself into posting a picture
kjb
Postby dieselboy1978 » Mon Oct 08, 2012 4:59 pm
I shall post a pic up later with invertor and split charger etc.
DELPHI
dieselboy1978
Postby dieselboy1978 » Mon Oct 08, 2012 9:22 pm
Find below pics of my invertor fitted on bulkhead.
Split charger and options for more stuff to be wired up as well as all been set up ready.
DELPHI
dieselboy1978
