Fitting Mk3 Mondeo Electric seats
Postby CamsTrans » Sat Oct 13, 2012 4:04 pm
Hi all; I've picked myself up some leather Mondeo seats on ebay. Was expecting basic leather seats but when they arrived I found a fully electric heated drivers seat and a heated passenger with a cd autochanger underneath it! I thought if I'm going to put them in I might as well have them working too. Anyone had any experience fitting these?
The drivers seat has just a single plug with 3 pins for it all then the electric controller that clips into the plastic vanity cover on the side.
The passenger seat has just 2 pins for the heating.
I'm leaving the yellow plugs be as they are the pretensioner's and airbags.
From a few google searches it looks like I can run the lot off a 15amp fuse so I'll be looking to use the under bonnet fuse box possibly then running that to the back of the heater switch (that I haven't got yet) and connecting it up with the instrument light cable for the radio so it lights up with the rest of the dash.
If anyone is interested in the cd autochanger they are welcome to it for postage cost I dont know if it works or not and it doesn't have the plastic case that you put all your cds in.. But if anyone wants to take a punt on it :wink:
Driver's underside
Passenger underside:
Driver's Plug and wiring colours:
Image Image
Passenger's Plug and wiring:
Image Image
58 Transit Connect swb LR 75 (Gone)
08 Mk7 Transit Limited swb LR 140 (Gone)
14 Transit Custom Limited swb 125 8)
CamsTrans
Re: Fitting Mk3 Mondeo Electric seats
Postby dieselboy1978 » Sat Oct 13, 2012 7:00 pm
Speak to Dub-77
He fitting exact same seats i believe mate.
If you want mounting plates for seat Mod Your Transit have plates i hade made by engineers and he now has the pattern to sell them.
Bank account emptied by
DELPHI
dieselboy1978
Postby CamsTrans » Sat Oct 13, 2012 7:25 pm
Cheers, I'll ask Paul about them.. Maybe he'll be able to pack them with my new shape rear lights when he gets them in. Mods galore for me at the moment :D
CamsTrans
Postby Dub-77 » Sat Oct 13, 2012 9:51 pm
Pm'd you mate. But basically drivers seat orange and white is live black earth should get the motors working as for heater I've not done that yet.
Cheers
Darren
Dub-77
Postby paul2012 » Sun Oct 14, 2012 3:28 am
I have fitted Mondeo Mk2 Leather seats (Fully electric) in my connect.
The mondeo mk3 seat fitment is Identical to the mk2.
I had to fabricate steel mountings with 2" pillars at the front for them, As the runners on the seat at the front actually seat higher than the back.
If you just bolt the seat to a flat steel plate, you will found that the seats are not level, are tilted forward & sit alot lower that the standard connect seats.
2009 Jaguar X-Type 2.0D
IDS & GM GDS2 services
paul2012
Postby dieselboy1978 » Sun Oct 14, 2012 1:36 pm
paul2012 wrote:I have fitted Mondeo Mk2 Leather seats (Fully electric) in my connect.
I have bolted mine to 10mm thick plate and have adjsuted the feet of the seat so they bolt flat and i dont sit any lower than i did in my connect seats and if you ask a few people who have done it this way you might find the same answer.
DELPHI
dieselboy1978
Postby CamsTrans » Sun Oct 14, 2012 3:00 pm
I'm going to ask Paul if he does any mounts as I don't have much time at the moment...But I may end up putting mine onto some box section or something; especially as I'll probably be able to pick it up for free :wink: All about knowing the right people and having a agricultural supply place about 2 minutes up the road is very handy and even better when you know the guys in the workshop
My last project they helped me with; just ignore any of my welding on it :lol:
CamsTrans
Postby Surfunitone » Fri Mar 09, 2018 11:19 am
i know this is an old post.... did you get this fitted? need to fit one to my MK7... i've just got the same seat and wanted to know about the base and wiring... not to fused about the heated seat part...
2.2 Duratorq-TDCi (110PS)
Surfunitone
