justyjust wrote:still got this issue with these electric mirror not operating, tested the yellow orange still only low voltage 0.3v this is at the switch.
where does this wire run back to?? the fuse box or somewhere else.
Or should i just pull the dash out and trace it back??
See wiring diagram, the OG/YE wire is the 12v+ power feed to the mirrors it runs direct from the back of fuse panel (connector C15 pin 13) to the drivers door wiring loom connector on O/S A-pillar (connector C41 pin 12)
Unplug the drivers door loom plug from it's socket, located on O/S A- pillar (to disconnect the drivers door loom from socket twist the plug & it will disconnect).
Check to see if you get 12v+ from pin 12 on the driver door loom socket on O/S A-pillar - NOT the door loom plug - all the pins in the socket are clearly numbered
There's no need to remove the dash
see post here for all pinout details on both door loom sockets
viewtopic.php?f=54&t=111468&p=972435
