highroof wrote:What if you have a '57 plate without heated mirrors? Any solution for that?
justyjust wrote:do you think this will work on my 2003 Reg 52 plate connect 220LX, i see your diagram but do you have any pictures of what you have does. pictures speak a thousand words
cheers justin
justyjust wrote:thanks for the info, how long of a job is it do you think? i have found a donor connect down the scrappy could i just remove the cables from that???
I do have a problem with my mirrors which i cannot get to work, they heat up but don't move when direction knob is moved can you help???
thanks justin
justyjust wrote:Tested the voltage on the fuse 14v but on the door orange/yellow I'm only getting 0.36v why would I be loosing voltage??
Is there a relay for the heated mirrors?
Cheers
