karl mcghee wrote:May be clutch bearing on the fork ??
taz666 wrote:karl mcghee wrote:May be clutch bearing on the fork ??
connects don't have a bearing on a fork, its a slave cylinder/ bearing combined and if there is a knocking noise when the engine is turned off then its probably the dmf
karl mcghee wrote:taz666 wrote:karl mcghee wrote:May be clutch bearing on the fork ??
My bad lol
gt_addict wrote:Sounds a bit like gearbox thrash. The rattle noise on mine was springs on te clutch friction plate. Change the clutch and should be sorted.
Mines a 90ps tdci 2004 plate and it had a solid flywheel
