Bad Vibration at 60-80mph, no noise tho?
Postby golfynut » Thu Apr 04, 2013 10:02 pm
Hi, I've got a 2007 110ps connect and get a bad vibration through the cabin floor at motorway speeds. There is no noise with it (apart from the bloody van shaking to bits) and the steering wheel is still. Nothing through the pedals and brakes in a straight line?? It does get worse under load but then fades at 80 plus. Has anyone any experience or knowledge of this problem and any possible causes? Thanks
golfynut
Re: Bad Vibration at 60-80mph, no noise tho?
Postby paul2012 » Thu Apr 04, 2013 10:09 pm
Possibly worn O/S driveshaft bearing ? As it can cause vibration issues
Check here as it may be listed
:arrow: viewtopic.php?f=54&t=124877
2009 Jaguar X-Type 2.0D
IDS & GM GDS2 services
paul2012
Postby fedup2 » Fri Apr 05, 2013 9:24 am
Wheel balancing or screwed tyre.
Launch x431 owner ;)
fedup2
Postby gt_addict » Fri Apr 05, 2013 9:42 am
I'd at least take a look at both rear wheels/tyres and make sure they are worn even. My mate had a similar issue and turned out to be a bulge in one of his tyres :/
gt_addict
Postby Keithm » Fri Apr 05, 2013 2:10 pm
Mine is doing this too but at 60mph, under load it is shaking like hell but once I lift of the throttle it disappears. Checked all tyres etc and nothing noticeable. It's going into garage Monday
Keithm
Postby kjb » Fri Apr 05, 2013 2:33 pm
Had a 2006 tddi connect do exactly this recently,replaced both driveshafts which corrected the problem
kjb
Postby fireblade28 » Fri Apr 05, 2013 3:08 pm
Check your engine and gearbox mounts
fireblade28
Postby golfynut » Fri Apr 05, 2013 10:19 pm
Cheers, I'll look into that and post an update.
golfynut
Postby golfynut » Sat May 11, 2013 3:01 pm
Thanks for all the possibilities. It turned out to be the flywheel which in turn had shagged the engine mount. All good now
golfynut
Postby OllieM3 » Sun May 19, 2013 8:37 pm
Hello,
I too am having this same issue. Between 60 and 70mph there is a bad vibration through the steering wheel which disappears when you let off the throttle. Would be very keen to know what could be causing this as its very uncomfortable.
Thanks, Ollie
OllieM3
Postby OllieM3 » Mon May 20, 2013 11:36 am
golfynut wrote:Thanks for all the possibilities. It turned out to be the flywheel which in turn had shagged the engine mount. All good now
Hi - how did you establish this was the problem? I need to check this out on ours. Cheers
OllieM3
Postby Keithm » Mon May 20, 2013 7:52 pm
Had mine into garage few weeks ago for same problem.
Mechanic took out and Inspected both driveshafts, he said he could find nothing wrong with them so replaced them and road tested the van and The vibration had completely disappeared!
It stayed this way for for a few days and now its back again :(
Keithm
Postby gt_addict » Mon May 20, 2013 7:59 pm
Keith, did he check the bearings on the half shaft or whatever it is on the long sides one coming out the gearbox?
gt_addict
Postby Keithm » Tue May 21, 2013 1:27 pm
I have no idea mate, its something I will ask when I get a chance to get it back in again. Cheers
Keithm
Postby Keithm » Tue May 28, 2013 10:24 pm
Had my van in to another garage for this problem today as i wasnt happy with the outcome from the last Garage.
It was the N/S driveshaft that was causing the vibrating, 2 of the 3 bearings within the rubber boot nearest the gearbox had collapsed. I've gotten the van back tonight and yes I'm pleased the vibration has stopped
However the van is wandering all over the road now. Trying to drive it down the dual carrage way and its all over the place, when I accelerate it pulls to the right and i find myself steering left to keep it in a straight line, of cause when lifting off the throttle to change gear it pulls left due to compensating while accelerating.
If I accelerate hard in 2nd it pulls violently over to the other side of the road.
Spoke t the mechanic on the phone when I got home and he said "I've road tested it and its normal tondo that its called torque, the ford boys get it alot and just compensate with the steering. What a load of bollocks its an 18 diesel not a focus rs!!!
Needless to say I'm friggin fuming with mechanics!!
I'm taking it for tracking in morn to see if this corrects it.
Any ideas what would cause this???
Cheers
Keithm
